Old 10-06-2014, 09:33 AM   #21
Originally Posted by linderpat View Post
to be clear, cost is not an issue for me. I do not "cheap out" on any of my cars. Instead, I am wondering about performance issues. Wondering if dino oil would be better at silencing clattering lifters. Jeff provided an answer - oil life is shorter. which is not an issue for me as I would just change it more often. Also varnish build-up - this is a potential significant issue. Any other performance concerns? Sythn seems so thin. I never use Mobile 1 on my 928 for instance. That car has never had even the slightest drip, but one time I used M1 and it leaked. Drained it and went back to my favorite brand of dino oil and never had another drip (although now I use Royal Purple in it with excellent results).
Anyway, my Boxster does not leak, so that is not a concern to me. Instead, it appears to my unscientific observation that dino oil of the same weight as sythn is "heavier" to the feel, or more viscious feeling.
Thoughts?
Synthetics are a different world; they have higher heat transfer capabilities than conventional oils, lower surface tension (hence your leaks), lower coefficient of friction, much higher shear capabilities, etc., etc. This is why they have taken over the high performance market. They are simply a much better product.
As for quieting lifters, as this problem is related to the incredibly small oil passages in the valve train oiling system, synthetics should do a better job because the flow more easily. One trick you might want to look at is to go with a higher film strength synthetic, replacing a 0W -r 5W-40 oil with the same brand 10W-40.......
Old 10-06-2014, 09:54 AM   #22
linderpat's Avatar
thanks Jeff - that makes sense. I will try the slightly heavier weight and see what happens.
Ed
Pittsburgh, PA
78 5 spd 928 Blumaxx (in Hemmings S & E issue #100)
85 928S garnet red stock daily driver
06 Mustang GT Legend Lime and modified to go even faster
linderpat is offline   Reply With Quote
Old 10-07-2014, 06:39 AM   #23
You mean these cars need oil?
Old 10-07-2014, 10:09 AM   #24
Oil, gas, air and $$$. That is what they run on.
