Old 06-26-2013, 08:42 AM   #1
If the rear is knocking....
I get a light vibrato type knock over light bumps. Almost a rattle but low pitch in sound... Sway bar drop links? The car is going in for alignment on Thursday. I'm not getting any movement in the suspension when I poke and prod, and it does not make noise in the turns or over larger bumps,it's primarily over things light small speed bumps and pavement abnormalities.
I know that diagnosing suspension problems over the internet is sort of a silly request, but thought I'd ask if this is a typical mode of failure...
Thanks!
shadrach74 is offline   Reply With Quote
Old 06-26-2013, 09:12 AM   #2
edc
550 Anniversary
edc's Avatar
Sounds like snooker/pool balls? Then probably wishbone balljoint.
Current: 550 Spyder Anniversary- Carnewal exhaust - 100 cell cats - stainless manifolds - 4" underdrive pulley - poly gearbox mounts - rear lower alu brace - adjustable rear toe links
Sold: 986S - Zenith Blue - 18" Sport Classics - Black Zunsport grilles - Stainless silencer and manifolds - K&N panel - shortshift - M030 suspension - 75mm throttle body - custom 83mm intake - SmartTop - custom remap - MDS underdrive pulley
Old 06-26-2013, 12:39 PM   #3
Or rear trailing arms. Vertex sells urethane rebuillds for $140ish. Exact symptons of mine at 60K. The front rubber bushings go fast.
navair is offline   Reply With Quote
Old 06-26-2013, 02:22 PM   #4
tanque55's Avatar
I'd say the rear control arms also. The original rubber gets soft and you can hear it when you hit a bump or turn. I just replaced my front control arms Sunday and the original rubber bushing was super soft. The replacement had the urethane bushings that should last forever.
tanque55 is offline   Reply With Quote
Old 06-26-2013, 08:25 PM   #5
Sounds like drop links. They'll rattle if they're a quarter turn loose.
98 Arena Red 986
Stroked & Blown is online now   Reply With Quote
