Old 06-24-2013, 01:15 PM   #1
Hard starting
I'm having some summertime blues. 1998 2.5 is hard to start in hot weather after running about 40 miles or so then shutting it off. Get back in after 15 minutes and the beast won't catch. I have to crank it several times and pump the accelerator to get it to start. By cranking, I mean turn the key and hold for a couple of seconds then turn it off and repeat until it fires. Any ideas what to look for?
davedeck is offline   Reply With Quote
Old 06-24-2013, 02:29 PM   #2
Possible fuel pressure issue (pump, pressure regulator). Try running the car with a fuel pressure test gauge attached to the test port on the fuel rail to see if the system is losing pressure. Another perennial favorite is the crank position sensor, which can act up when hot, causing the DME to turn off the fuel pump. You can test the CPS:
1. Connect ohmmeter connector part to rpm/crankshaft position sensor, pins 1 and 2.
Display at 20 °C: 0.8 – 1.0 k Ohms
2. Connect ohmmeter connector part to rpm/crankshaft position sensor, pins 1 and 3.
Display: infinite ohms
Old 06-28-2013, 02:52 PM   #3
I'll give it a try
Old 06-25-2015, 05:24 PM   #4
To double check: if the ohmmeter readings confirm the above, then the CPS is not at fault for the issue?
luckyed7711 is offline   Reply With Quote
Old 06-25-2015, 06:03 PM   #5
It means that the CPS is functioning correctly under the existing conditions. Problem with a CPS is that you need to check these tests when the car does not want to start, like after a heat soak. If the tests check out then, it is probably not the CPS.
Old 06-25-2015, 06:15 PM   #6
I see. Yes. Thank you for the clarification.
