Old 06-27-2013, 04:02 PM   #21
edc
550 Anniversary
edc's Avatar
Its all of about 5mm. Worrying about resale value is a waste of time when there are far more other things to consider which will actually fail, need replacement or repair. You won't even notice the difference unless somebody told you it was done and you undid the nuts!
Current: 550 Spyder Anniversary- Carnewal exhaust - 100 cell cats - stainless manifolds - 4" underdrive pulley - poly gearbox mounts - rear lower alu brace - adjustable rear toe links
Sold: 986S - Zenith Blue - 18" Sport Classics - Black Zunsport grilles - Stainless silencer and manifolds - K&N panel - shortshift - M030 suspension - 75mm throttle body - custom 83mm intake - SmartTop - custom remap - MDS underdrive pulley
Old 06-28-2013, 03:59 AM   #22
My car is worth nothing as it is. If anything it will be worth more to the right person if I get it really sorted.
Enthusiasts understand this kind of stuff and if they know exactly what they're buying won't be put off. Or as above, if you're OK with it just don't say anything. Zero chance of anyone spotting drilled turrets.
pothole is offline   Reply With Quote
Old 06-28-2013, 03:56 PM   #23
Steve Tinker's Avatar
I have a pair of front GT3 monoball shock mounts if anyone is interested, not new (approx 5,000 miles only ) - Part #996 343 181 9R.
When I fitted my PS9's I decided to stay with the standard rubber bushing top mounts as I have got nearly -1 deg already with my setup.
2001 MV Agusta F4.
Old 07-01-2013, 02:42 AM   #24
Bfan's Avatar
How much do you want for them?
Bfan is offline   Reply With Quote
Old 07-01-2013, 04:42 PM   #25
Bfan - make me an offer and I can then work out the postage to Iceland......
2001 MV Agusta F4.
