Old 08-13-2013, 10:09 AM   #1
chipmunk's Avatar
My Boxster went in today to Wrightune to have the IMS Guardian fitted - if you have a 24k or later service done then you get free fitting. I needed a major service so decided to do the two together.
The car has done 69k so (I am led to believe) is less at risk from IMS failure - none the less I will be happier knowing that there is some form of warning in case the bearing starts to self destruct.
2003 Boxster S
chipmunk is offline   Reply With Quote
Old 08-16-2013, 02:21 AM   #2
chipmunk's Avatar
Originally Posted by hossuk View Post
Also I had to install the switch with the visual indicator on the drivers side of the dash and found it was totally obscured by my hands and the steering wheel when it's in its's most comfortable position for me.
I have exactly the same problem. I may follow your advice with the leds and connect them to the aux output.
2003 Boxster S
Old 08-15-2013, 06:25 AM   #3
I just installed it on my 1998 Boxster this week. The car has 104K, I sleep much better at night now! This issue was driving me nuts!
Goodbiketime is offline   Reply With Quote
Old 08-15-2013, 06:36 AM   #4
recycledsixtie
recycledsixtie's Avatar
I have had the Ims Guardian installed for two years now. Has anybody with it installed had the alarm go off yet?
Old 08-16-2013, 02:16 AM   #5
chipmunk's Avatar
IMS Guardian all installed and working. Lets hope it never goes off!
2003 Boxster S
