Old 06-02-2013, 05:36 PM   #4
enroute1's Avatar
Can't really explain it any better than I did...
"This occurs in any gear moving along when you take your foot all the way off the gas pedal and when you put your foot back into it." (not sloppiness, just movement when accelerating and decelerating. Not when shifting.
I am just hoping to find out if anyone else driving one of these cars experiences a slight 1/4 inch movement in the shifter while cruising along in gear while letting fully off the gas and then getting on the gas again. You can feel it if you keep your hand on the shifter as well.
I am sure that it is moving with the engine movement. What I am not sure about is if it is normal or if any other drivers can tell me if it happens to them as well...
It did it with the old hardened cracked mount as well...a bit more actually.
Wish I had another one to test drive
2000 2.7 Boxster 5 spd. Ocean Blue Metallic 28K miles
http://s79.photobucket.com/user/fr3dm/slideshow/Porsche Boxster
enroute1 is offline   Reply With Quote
