Old 05-20-2013, 09:50 AM   #1
pulling cam covers
I used the search, but I found no info on my question.
Both cam coves are leaking enough to create smoke when stationary. Tried to re-torque and that made it worse. I have the cam lock left over from the IMSB retrofit that was done at an indy.
2 questions:
1) What size bolt is used to hold the cam locks in place.
2) the cam locks that came with the IMSB retrofit look very different from one another. Does the IMSB retrofit come with the tools to secure both cams on the 5 chain engine in my 2002 S?
I suspect the IMSB came with one cam lock for the 5 chain engine and one for the 3 chain engine. I am in a pickle as to how to secure both cams at the same time without spending money on buying or fabing a second part...
Ross
shadrach74 is offline   Reply With Quote
