Old 05-13-2013, 05:29 PM   #1
truegearhead's Avatar
test pipe + no check engine light
I can't believe I can't find this, but I know I've read about it on this forum. What do I need to run a test pipe and not get a check engine light?
2003 911 C2
NASA HPDE Instructor
Old 05-13-2013, 05:45 PM   #2
The Radium King's Avatar
1) just tie-wrap them up underneath your car. free, works for some.
2) buy two spark-plug anti-fouling adaptors. use these to offset the sensor from the exhaust flow. $10, works for some.
3) buy some o2 sensor foolers (fvd sells them). what, $100 or something, works for some.
4) ROW ecu flash - euro cars don't throw a code if no cats. free if you know someone with a piwis or pst2 tool, otherwise you gotta convince your shop to do it.
4) Custom ecu flash - sets ecu sensor thresholds such that the exhaust doesn't trigger a code. $600 to $1k.
Old 05-13-2013, 06:12 PM   #3
wait...you mean I can just tie wrap the sensors under the car and open to the air and then use plugs on the test pipe? Good enough for me
2003 911 C2
Old 05-13-2013, 06:28 PM   #4
Johnny Danger's Avatar
Which boxster do you have ?
Old 05-13-2013, 07:03 PM   #5
What year is your car? The the 4 cat systems need nothing but the pipes themselves and an hr or so of wrenching...
shadrach74 is offline   Reply With Quote
Old 05-13-2013, 07:37 PM   #6
Precisely !
Old 05-13-2013, 07:44 PM   #7
complete fail by me. I was thinking catless. you have cats on your headers.
Old 05-14-2013, 07:06 AM   #8
Homeboy981
Homeboy981's Avatar
A Cat Bypass should be fairly benign and not throw a CEL.
Most the rear Cats are not monitored, on certain MY cars. Hence the need for the year and model of your Box. Help us, help you.
Old 05-15-2013, 02:17 PM   #9
It's a 97 2.5 ....I know I should have worked harder in school
2003 911 C2
Old 05-15-2013, 02:49 PM   #10
Since the 2.5 only has one set of cats, if you delete them, it will render the vehicle non OBD II compliant and CELS's will result. The only real way around it, is to re-map the ECU.
Old 05-15-2013, 02:52 PM   #11
Or to be more precise... you need a ROW flash...
