Old 12-15-2005, 12:44 AM   #1
Send a message via AIM to blinkwatt
Toluene
Does anyone here know any bad side effects of toluene? It is time to fill up this weekend and Im considering mixing a gallon or so with a full tank,unless someone tells me otherwise.
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 12-15-2005, 03:30 AM   #2
bmussatti
Guest
Posts: n/a
Why so much? What is the objective? Fuel cleaning or octane boost?
As a fuel cleaner, you only need about 6 ounces.
Do a search, blinkwatt, there has been much talked about here regarding octane and power. Just because you increase octane, it does not mean you will increase power.
MNBoxster threads should proved most insightfull to you. Go search his threads.
Old 12-15-2005, 09:59 AM   #3
toluene safety
Here is a link to a MSDS for toluene:
http://www.jtbaker.com/msds/englishhtml/t3913.htm
Dan, 2002 C2 Black/Tan
cyclocross is offline   Reply With Quote
Old 12-15-2005, 04:37 PM   #4
DUde, I saw a comparison with Toluene, NOS, and another gas additive to boost your octane levels from European Car Magazine. I'm trying to find it and will post.
KRZ
KRZTACO is offline   Reply With Quote
Old 12-15-2005, 05:31 PM   #5
Hi,
Good Point! Like so many things, Toluene can be very hazardous if used improperly. But, if used in a well-ventilated area and wearing the proper protection, there's little hazard to it. It is a common ingredient in Gasoline...
Happy Motoring!... Jim'99
Old 12-15-2005, 09:57 PM   #6
Perfectlap's Avatar
if it aint broke don't fix it! advice I should have followed once while tinkering with the gears on my $4,000 bicycle.
BORN: March 2000 - FINLAND
Old 12-16-2005, 02:12 PM   #7
if you use too much it could mess up the spark plugs
porscheguy is offline   Reply With Quote
Old 12-16-2005, 02:41 PM   #8
Found IT..A MUST READ
http://www.europeancarweb.com/tech/0503ec_techboost/
