Old 12-15-2005, 10:40 AM   #1
PorscheCrazy's Avatar
Check Engine Light Flashing
Hello,
My CEl, first came on last week, I took the car down to the dealer and he pluged up his OBD2 tool and it pointed to the 02 sensor weird thing is, both banks were ideal. Yesterday I took the car out for a brief drive and the light started flashing and I began to lose power It stopped flashing after about 3-4 mins.
I was luckily about 5 mins away from the dealer and brought it by. The dealer checked and said there were multiple misfires, any idea what this could be?
The shop tech said it was lickley a gromell, attached towhat I dont know.
Please help!!!
PorscheCrazy is offline   Reply With Quote
Old 12-15-2005, 11:27 AM   #2
Is there another dealer nearby? Your CDL (Check Dealer Light) is on.
Good luck!
Mike
04 Boxster S - Basalt/Savanna, 6sp, Carrera lites, hardtop
70 914-6 - Black over tan, original/stock
PCA since 1970
70Sixter is offline   Reply With Quote
Old 12-15-2005, 11:32 AM   #3
They have been pretty good in the past, I should have mentioned that I took the car through a carwash, it is rather cold here. And the high pressure water may have broken the gromell. WTF!!
ANYONE ALSE have any idea of what to expect? or better still what the hell it is?
Old 12-15-2005, 02:17 PM   #4
deliriousga's Avatar
Most important, if the CEL is blinking don't drive the car. The blinking means it's serious enough to cause further damage. You need to go to AutoZone or some other place and get them to pull the actual code numbers instead of just "several misfires". The codes will tell you what bank is misfiring and if any other sensor codes are going off too.
There are so many things that can cause misfires, you really need more accurate info to help with diagnostics.
1966 Wife White/Brown Top
Old 12-15-2005, 08:34 PM   #5
The independant porsche shop had found an o2 sensor malfinction, and multiple misfirers particuarly 6.
Old 02-14-2006, 11:57 AM   #6
Blinking CEL
I had this same problem with mine at just over 20k mi. Had it towed to dealership and they ended up having to replace the engine. They said that there were some metal shavings in the oil. Luckily warranty covered.
03Boxster Guy is offline   Reply With Quote
Old 02-14-2006, 01:00 PM   #7
No My car made it out in is in great shape, looks like the previous owner took on more than he could chew and neglected the car's maintance, after a full 60K service and an ignition switch, and an ignition coil all is well.
Old 02-14-2006, 01:22 PM   #8
PorscheCrazy, do not put that car through another car wash. High pressure water can shoot straight up the intake on the driver's side and saturate the filter with water. When you drive the car, the water-logged filter then releases the water past the MAF and into the intake manifold and voila! You have a screwed up engine.
Rain won't find its way into the engine, but a strong blast of water has far more force.
CE light on = get it checked out soon
CE Light blinking = Pull over and get it towed to dealership or mechanic.
Old 02-14-2006, 05:04 PM   #9
Yeah your kinda preaching to the choir on this one, this happened 2-3 months ago.
Old 02-15-2006, 07:50 PM   #10
Strangely enough I've had the "dreaded" blink on two occasions just for a few seconds and then it went away. I guess it's all good though because I haven't seen the light blink in quite some time and I've never seen a solid CEL. Strange. I think the ECU was confused for a sec I guess. The car runs stronger than ever.
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
Old 03-09-2014, 04:38 PM   #11
Chris B's Avatar
Bumping this thread...
I've searched through the forum but haven't found anything similar to what I had today. I was at a stop light, CEL flashed 3-4 times and stopped. The car was/still is running fine. Kept driving home for another 30 mins or so and haven't seen the light again. I guess I'll need to run codes? Any other input on why this would happen, stop, and not return?
2001 Boxster S
Arctic Silver
Black/Black
18" GT3 Design Wheels
LNE IMS
Chris B is offline   Reply With Quote
Old 03-09-2014, 06:35 PM   #12
Momentary issue that went away. Most likely there is code stored even if the CEL turned off. I have read that this can happen with a misfire that is bad enough to illuminate the blinking CEL but then returns to working ok so the blinking CEL goes away. Check to see if a code is stored.
Old 03-10-2014, 06:41 PM   #13
Happened to me two weeks ago in my BMW. Two of the 8 coil packs were faulty, but not totally shot.
