Old 04-23-2013, 08:35 PM   #1
The Radium King's Avatar
electric power steering project
slowly putting the gear together:
- Vauxhall astra/zafira electric PS pump c/w mounting bracket ($200; used on ebay uk):
Vauxhall Astra MK5 H 2004 2010 1 3L Diesel Cdti Electric Power Steering Pump | eBay
- two GSR PS rack to 6AN male fittings ($110; to convert PS rack to AN fittings):
GSR Power Steering Rack Fittings - 6AN - Porsche 986, 987 Boxster, 996, 997 911
- Pending: Russell 16mmx1.5 o-ring seal to 6AN male fitting ($8; to convert electric PS pump pressure side to AN fitting):
Russell 648060 Russell Power Steering Adapter Fittings
- Pending: two 6AN female/female hoses ($?; depending on length).
notes:
- PS pump bracket can be easily bent to mount on flat surface, and comes with three rubber vibration isolation mounts between pump and bracket
- if mounted on upper tray of front trunk will clear hood (mounting on upper tray will also give good access to battery and keep main trunk free for helmets)
- original PS pump can be gutted to serve as dummy pulley if you have deleted AC (thanks eric) otherwise all required is a shorter belt; suncoast and bgb also sell AC delete pulleys (marketed for the 987.2, but will fit the 986 as the AC compressor part number hasn’t changed)
- PS pump wiring is as follows:
red - battery +12V
brown - ground
black - ignition +12V (i.e., only runs when key is on)
blue/white - alternator dash light (to turn it off if the key is on but car not running)
brown/white - not required (for diagnostics)
need to confirm:
- 6AN hose will fit over reservoir return spigot (presume not a big deal)
- source for Bosch 4P weatherproof male electrical connector to connect to PS pump electrical connector (for clean install, otherwise i can splice the wires)
- that i got the proper Russell fitting (presume metric, but could be 5/8”)
- hose length and routing from PS rack to proposed mounting location
- appropriate grommets to give bulkhead penetrations a finished look (got a box of them; something should work)
- source for switched +12v and alternator wires (under the dash somewhere; just need some time with the wiring schematic to get a colour code)
almost there; cost will be around $400 all in.
Old 04-24-2013, 05:03 AM   #2
psp
Thanks for the info, I'm getting ready to do this mod on my car and all the info on the process would be appreciated
goldsc_78258 is offline   Reply With Quote
Old 04-24-2013, 11:40 AM   #3
woodsman's Avatar
there are those that talk and then those that do! I respect your quest and all the work you are doing Radium King. And thanks for sharing the fruits of your labour!!
Old 04-24-2013, 05:34 PM   #4
Moderator
Very nifty and skillful you can do this. Am subscribed to this thread.
Old 04-24-2013, 08:15 PM   #5
thanks; hopefully not too much skill involved - drill a few holes, connect two hoses.
i'll have the front underbody panels off the car in a week or so and can confirm hose routing/length, at which point I can order hoses and the Russell fitting (I live in the boonies so have to order stuff in batches to save on shipping). that should let me know I have the proper fitting for my pump. after that I have to find some time to test, clean and paint the pump (it's used and has spent some quality time under the hood of some diesel british people mover). then I expect a day (or two) of actual install.
Old 04-25-2013, 07:33 AM   #6
jaykay's Avatar
Sounds good. Why did you choose this particular pump? What is the output with respect to the stocker? It's probably much more stable and will give the ps control valve less work.... but output pressure range?
It would be really handy if the ps control valve was right in the frunk somewhere....are you drilling to get to it??? Perhaps it's modularized with the rack....bummer
Are you removing all the ps lines from the back?
Will the gutted ps pump require some fluid to keep its bearings cool and lubed while idling? Will you still have to service this fluid?
986 00S
Old 04-25-2013, 07:45 AM   #7
oil and transmission coolers
Old 04-26-2013, 08:22 AM   #8
jaykay's Avatar
Ahhh you have to get right to the rack....that means big holes for the hydraulic lines!
Who would have thought that a Porsche cup car pump would be a Vauxhall Astra piece...crazy!
Where do you plan to grab switched power for it?
986 00S
Old 04-26-2013, 08:54 AM   #9
smallish holes - 6AN (AN/16 = 6/16 = 3/8").
switched power under dash - stereo, etc.
ill try to get some pics up of proposed placement this weekend.
Old 05-03-2013, 09:26 AM   #10
Here's a shot of the pump. You can see the opening for the pressure out, as well as the barbed return to the reservoir. You can see two of the three rubber isolation mounts on the oem bracket, and that with a bit of bending you can make the bracket mount to any surface you want. For wiring you see the main + and -, as well as the three-wire control connector.
A clean and a shot with a spray bomb (black plastic paint for the reservoir and some black high temp for the motor) and its ready to go in.
On another note, a quick peek of a Ruf 3600 clone coupe (zeintop):
Old 05-20-2013, 01:27 PM   #11
electric P/S
Just finished the install and tried it this week end at an autocross event, It worked like a charm, the steering is a little tighter but the feel is better than before. I ended up running a switch instead of the alternator light because it's more practical since it is a race car.
It was an easy project with all the info that I got out of this post
Thanks for all the research RK
Old 07-09-2023, 11:55 AM   #12
so, super necro-bump to this thread. turns out that using the trw pump is big in australia (off of holdens) with lots of aftermarket support.
brackets:
https://www.ebay.com/itm/155636585037?hash=item243ca9d24d:g:PXQAAOSwUDBj6Jm B&amdata=enc%3AAQAIAAAA8MDwtw6vWoDd2KwdDKKNmq2iYgebP 3W4ugdwLpMzkzy%2FJinL5gzUk176XRHzbaQNy0OEwTtLmFeYq 31WjaL%2FKemW2YdSrfcrOq328TthMTInSkqN2%2Fsn0cjlBDF kBDlNr5HecpwlSxFaXNgXb1m%2BoKPMMevumJcxtIOzizI%2FD FIQ%2FExfhVWAMnU%2BVMueaFVpEvAa83Kx%2F2QqUU2f0lJNE X43cYVPyeK0xKi7UtIMTIbSxcF7GxAPjM0rgNKPctr31O3zlG4 XsJt34s8ML9xLFRBY0qYmaKwVevTu5SRKMxvTgR%2B7y4aneRb pVmolm7IUBQ%3D%3D%7Ctkp%3ABk9SR8KIhcCnYg
https://www.ebay.com/itm/284298166780?hash=item42317dc1fc:g:1rQAAOSwNDlhAn-J&amdata=enc%3AAQAIAAAA8A5HPfjwTrJd3ary4bEDHq88K9q4N onVbSm8zNHzCD%2FCWXYkep%2BZFHs6JNSfr0jbduAQ7upja%2 BHcxEektgc3pAYZkUPhoXRNP6QVYJ%2FIRyWbhjXPg%2BY1tTJ ZpJUlbKNJhBuTYSOp%2B7Mcdd2Guj2xwLvBlp91eRfnBOanfIx xoQ6Gr6rUi7aE4YR0XB8nJUSsGbmRmv%2FCe33vuqbo4%2B7VY %2B0pVXsWA7fjiHCwugIQROHtyRS9G626mgURjirF%2B%2Fijr Hb4n%2Fn7AVeFyAkl899sRkL6b0cNMNkoUPwtZ4p9ncePhcZYl pMjY%2FfsjM6nh7NYmQ%3D%3D%7Ctkp%3ABFBMwIiFwKdi
https://www.ebay.com/itm/284371301496?hash=item4235d9b478:g:MOkAAOSwM3hg7rO H&amdata=enc%3AAQAIAAAA8ILRhFpD2fcE9wDf7zEoQtHDdWZy% 2BWT%2FbpKl03l%2BXUX%2BD7PnoJQg1C1wxXEDQlPe5qTUjrD d0NdVjE9Pc6YVrXbM5DDNOpg6gXCUPzaZ1FOUHUTLOVkiQry3F %2FWXrAq19rpnpzhg0j5XBfnq64H3MgMM5bTtTpRQ2xxi5FLKm 5sAWCHpGZzSOgNubFV27sM6qDjhp8TuG1CDJK7aDC1Hs3BhhTi YWe9DkeaoWS7FvtFL8TqqC4vLvkLML42W%2BYeIfePZLGlfv2S Wl6%2FqrL8LzC9FXgvOk%2Bl7BKzS4TO4w5M0bsbtfyewqQG2M 0VS1IF8hQ%3D%3D%7Ctkp%3ABk9SR8KIhcCnYg
pumps that come with the AN fitting:
https://www.ebay.com/itm/175720670340
wiring info:
https://www.shiftkits.com.au/documents/astra-power-steering-pump-wiring/
Old 07-09-2023, 06:03 PM   #13
Mine is installed with a 60 amp power circuit breaker straight from the battery and the relay coil is connected to the windshield wiper power which is local and ignition on.
obthomas is offline   Reply With Quote
Old 07-10-2023, 11:54 AM   #14
Anyone have any pics of the finished project, and specific fitting pieces? I'm intrigued, as my stock pump is overheating at the track. I am getting the underdrive pulley, but this seems like it would be even better, although more work.
redpepperracing is offline   Reply With Quote
Old 07-10-2023, 12:19 PM   #15
buy the bracket. buy the pump with AN fitting. get the following steering rack fittings:
https://www.rsrproducts.com/product-page/rebel-s-racing-rsr-steering-rack-fittings-for-elec-pump
o-rings and fluid from local porsche dealer.
then you just need to fabricate two -6AN hoses and wire it up.
just search 'cup car electric steering' and whatnot for pics.
Old 07-10-2023, 03:57 PM   #16
A simple solution is to install a cooling radiator at the return line of the steering rack.
Old 07-11-2023, 09:27 AM   #17
for sure, but electric PC reduces parasitic load on the engine and sheds a few pounds in the process.
and is a cool thing for those that like to tinker and can't leave well enough alone ...
Old 07-12-2023, 06:28 AM   #18
Old 07-12-2023, 12:19 PM   #19
Thanks! Is that the MR2 pump?
Old 07-12-2023, 03:13 PM   #20
yes. Cap says use only Toyota fluid.
