Old 07-13-2023, 06:54 AM   #21
That is why I asked. I see lots of different options, Astra, MR2, Volvo, just trying to find something local, and cheapish. Not in any rush, probably a winter project.
redpepperracing is online now   Reply With Quote
Old 07-13-2023, 08:44 AM   #22
The Radium King's Avatar
bahahahaha. my favourite quote:
"What part of Porsche Racing did you think is going to be cheap-ISH, is it the the Porsche part, or is it the Racing part?"
Last edited by The Radium King; 07-13-2023 at 10:44 AM. Reason: political correctness ...
Old 07-13-2023, 08:57 AM   #23
I never thought it was going to be cheap, just trying to spend wisely. I also said 'cheapish', not expecting there to be an extremely cheap option, especially for something I don't necessarily need.
Old 08-14-2023, 06:55 AM   #24
Question for those who have done the conversion, do you use fluid recommended for the pump, or the rack? I sourced a pump from a 2017 Nissan Maxima, and it says to use Nissan EPS fluid, of course the stock Boxster fluid is CHF11s.
Old 08-21-2023, 05:57 AM   #25
Anyone have any insights they would care to share?
Old 06-16-2026, 07:29 AM   #26
To follow up on my own question, I ended up going with a kit with the TRW pump, and I am using the stock Pentosin fluid.
Old 06-16-2026, 09:47 AM   #27
here's an insight - if for a street car and you plan to locate the punp on the passenger-side shelf in the frunk, the trim panel for a RHD drive car (which has the brake booster on the other side) can be used to make the install look OEM.
Old 06-16-2026, 11:31 AM   #28
oh man, that is brilliant. I designed and 3d printed one that looks ok, but yeah, a factory one would be killer. off to ebay...
Old 06-16-2026, 01:53 PM   #29
I have one of those around, let me try again with this pump and reservoir (previously found I couldn't align the reservoir with the opening of the trim part).
Marc_986 is offline   Reply With Quote
Old 06-16-2026, 06:06 PM   #30
The 3G MR2 pump is also rare and stupid overpriced these days. Ford makes one used in Mazda and Volvo cars, common, cheap, and lower in overall profile, friend of mine uses this on his raced 91 Honda Prelude.
Forgive my ignorance, who makes "Vauxhaul"?
BrakeExpert is offline   Reply With Quote
Old 06-16-2026, 07:16 PM   #31
british - find 'em on ebay uk. used to be owned by gm along with opel.
Old 06-17-2026, 07:14 AM   #32
I don't think the RHD cover will work, at least for where my pump is mounted. Here is V2 of the one I designed:
It's not terrible, but I'd like the top to be bigger. This maxed out my printer, so I'll probably break it into smaller pieces and glue them together.
