Old 04-11-2013, 10:10 AM   #1
The Radium King's Avatar
oil cooler location
question: building an oil cooler setup for my box. using an lne adaptor into a canton sandwich plate. sandwich plate will feed a tstat that will send oil to a setrab cooler when hot enough. going with -10AN fittings. looking for a good location for the cooler. i see a lot of racers vent their rear bumper and locate the cooler there. i have the AC out of my car and was thinking of locating the cooler in the front to avoid fans, ducting, etc., also to move some weight foward. wondering if the oil pump can make enough pressure to push the oil the distance, or if i should keep the cooler closer and the lines shorter.
thanks for any help.
