Old 06-13-2012, 06:34 PM   #1
Transmission Compatibility
I've got a Boxster project car w/o engine or trans, and am looking at what manual transmissions might be a good swap in the car. The engine going in isn't quite decided yet, but the letter V and the number 8 are in play.
The boxster trans is too expensive for my under $5k project.
I don't mind fabricating, but why make it harder.
The engine will have 250-350 hp, so it can't be something whimpy.
A 944 trans are fairly easy to find, and appears to have the same 6-bolt attachment for the axles shafts, that looks like a plus if it does.
I may have to go with a transverse setup, so any suggestions there would be good.
thanks,
jack
nimblemotorsports is offline   Reply With Quote
Old 06-13-2012, 06:42 PM   #2
Track rat
Topless's Avatar
All the adaptor hardware for mating an LS3 to a 997 trans have been worked out. This would be a sweet match if you have the dinero.
Old 06-13-2012, 08:09 PM   #3
well I don't have the dinero for a boxster trans, certainly not for a 997 trans.
but interesting, a LS3 v8 will fit in the boxster?
Old 06-13-2012, 08:50 PM   #4
03 PORSCHE BOXSTER 5 SPEED TRANSMISSION 2.7 | eBay
These guys are in Sac and reasonable too.
98 boxster
82 280sl parts for sale
feelyx is offline   Reply With Quote
Old 06-13-2012, 08:53 PM   #5
Moderator
Word around the forums is that Audi transmissions are compatible with boxsters. Supposedly they bolt right up, read about it a while back.
986 five-speed tranny - unmodified Audi 012?
Not bad if they are $200-$400.
Old 06-13-2012, 10:20 PM   #6
great, thanks!
Old 06-14-2012, 06:35 AM   #7
Track rat
Topless's Avatar
That is a shame. A 6.2L, 430hp Boxster would be a potent ride. With a cast aluminum block, the LS3 is very close in size and weight to a Boxster 2.5L motor. You would need the 997 trans to handle the high torque numbers without scattering parts though. Renegade is working on one of these transplants now.
Old 06-15-2012, 08:31 AM   #8
Best of luck with that...
kcpaz is offline   Reply With Quote
Old 06-15-2012, 07:33 PM   #9
off to a good start, it is with the help of people here just saved me $500 already.
Old 06-15-2012, 10:24 PM   #10
Moderator
Nimble, I'm glad that helped. However, engines are notoriously expensive for the boxster. There has been an Audi conversion and a Subaru conversion, but from what I hear it is extremely tedious and time-consuming. However, for the motorsport aficionado, engine swaps are very common for the dedicated. Based on what you have to say, I'd say an Audi V8 would be your best bet, as Audi and Porsche are practically sister companies. A guy did use an engine from an A8 but it looked messy with wires and two gear selector knobs in place!
You may have already seen it but here is the video in case you haven't:
Porsche Boxster V8 80% complete. - YouTube
Old 06-16-2012, 03:27 AM   #11
What about a mazda rotary, RX8???
howe is offline   Reply With Quote
Old 04-10-2013, 03:40 AM   #12
More's Avatar
So does this actually work?
1998 Porsche Boxster 986 Convertible.
More is offline   Reply With Quote
