Old 03-05-2013, 02:07 PM   #1
intermittent Tiptonic Function
Just got a 2001 Boxster with Tipronic. Sometimes for some real unknown to me the tiptronic will not work and stay in one gear. If I stop and restart the engine most times it comes back online. Whats Up?
artscape is offline   Reply With Quote
Old 03-06-2013, 01:48 PM   #2
Fluid level?
ZF makes it
PST2 or PIWIS need to pull diags on TIPs.
Old 03-08-2013, 05:52 AM   #3
Agree with Mike. If that doesn't help, I'd be looking real hard at the TCM (regardless of any transmission fault codes)!
"You finally got that Nazi-go-cart you always wanted." -Peer
http://i40.tinypic.com/ei6sns.jpg
pompous is offline   Reply With Quote
Old 03-31-2013, 04:13 PM   #4
HI , I'm new to this thread but I would suggest changing the transmission oil and internal filter .
It does require a fair bit of work as the filter is located internally within the gearbox !!
Just a suggestion , try and get more advice first before jumping into this
Hurdi is offline   Reply With Quote
Old 03-31-2013, 10:13 PM   #5
Joe B's Avatar
Trans fluid and filter change worked for "Wheeler Dealers."
