Old 01-30-2013, 07:47 PM   #1
Oil Separator Sensor
2001 S, 6sp w/69K in North Jersey (cool weather)
Check Engine light came on during the first drive after filling up. Diag codes lead to OIL SEPERATOR SENSOR. Reset it. Drove that tank of gas w no probs.
The light came on after filling up again.
Any words of wisdom on this?
Pjlew63 is offline   Reply With Quote
Old 01-30-2013, 09:31 PM   #2
thom4782's Avatar
Can you post the trouble codes?
Old 01-31-2013, 05:01 AM   #3
I'll get them
Old 02-02-2013, 02:33 PM   #4
P1128, p1125, p1132, p1130
Old 02-02-2013, 04:09 PM   #5
thom4782's Avatar
The problem could be caused by several things. Given that your seeing rich and lean faults on both sides of the engine, my best guess is that your MAF (mass air flow) sensor is either dirty or failing. Inconsistent MAF signals could cause the fuel mixture to be too rich or too lean sometimes. Seach for how to clean the MAF, give it a try, clear the codes and see if they come back.
Old 02-02-2013, 05:17 PM   #6
Ok. Ill do that. Thank you thom.
