Old 01-12-2013, 12:37 PM   #1
2002 boxster S thump noise when changing gears
My 2002 boxster S 6 speed makes a thump noise when letting off throttle and pushing in clutch to shift gears 1-3, moderate to heavy acceleration. Everything else operates normal. Could this be a motor mount? Thanks for any suggestions you may have. Also looking for good Porsche mechanic in Los Angeles area.
Focusapparel is offline   Reply With Quote
Old 01-19-2013, 08:27 AM   #2
I had this same problem and it was the motor mount. It was $700 for a Porsche mechanic to replace it.
kichi is offline   Reply With Quote
Old 01-19-2013, 10:27 AM   #3
srad34's Avatar
Changing the motor mount is pretty straight forward if you can get the car on stands and have a jack to support the engine while the mount is swapped. Pedro has a good guide for this job.
About 2 hours if you take your time.
It will all end in tears I tell you.......
srad34 is offline   Reply With Quote
Old 01-19-2013, 06:08 PM   #4
deptotpr's Avatar
$700.00? I will listen to the thump.
928-to-986-to-996
Tampa Bay, Florida
deptotpr is offline   Reply With Quote
Old 01-21-2013, 09:27 AM   #5
HAUSIDMT's Avatar
+1 should be very manageable to do as a DIY.
2002 Boxster S with a few goodies, my 2nd Porsche.
1st was a 1966 912 hand me down from pops
HAUSIDMT is offline   Reply With Quote
