Old 11-16-2012, 02:43 PM   #1
Angry EVO Cold Air Intake
I bought the EVO Cold Air Induction. One problem, I can't get the Resonance Chamber plug to fit in the freakin hole! It seems to be slightly too big. I heated up the tube and froze the metal plug, no joy. I lubed both pieces with soapy water also, no joy. Any suggestions??
navyc130fe is offline   Reply With Quote
Old 11-16-2012, 03:33 PM   #2
The Radium King's Avatar
have you tried 'trojan fire & ice'?
Old 11-16-2012, 04:53 PM   #3
Jaxonalden's Avatar
If the plug won't go, just reinstall the tube. Don't run the chance of doing permanent damage. The intake will run fine without plugging the resonance chamber.
Enjoy the response from the free flowing intake and sound!
Old 11-17-2012, 07:33 AM   #4
@TheRadiumKing, I have not tried that, but will give it a shot, thanks!
@Jaxonalden, I think I would do more damage if I left the hole open, would essentially be putting the snorkle back on, which is kinda defeating the purpose of the new intake. And I can't wait for the new music! I also installed a new sport exhaust, this thing should sound amazing! I see you hav ehte EVO on your car, any problems putting it in??
Old 11-17-2012, 07:37 AM   #5
Homeboy981
Homeboy981's Avatar
Snorkel? That is for diving. Have you removed the snork PRIOR to installing the Cold Air Intake? I'm pretty sure it HAS to come off there!
Another option is to set it in the sun, apply WD-40 (one of its' many uses) and slide 'er in!
If that is not it, take a pic and post it….must be something peculiar.
Old 11-17-2012, 07:44 AM   #6
@Homeboy981, actually the Snork was already removed and capped, which I was surprised about, thought they came from the factory with one. It looked like a stock intake tube, had the resonance chamber on it... I'll try your suggestion too. Going to hit it again tomm. Replacing the exhaust was actually 1000 times easier than this! Go figure...
Old 11-17-2012, 09:43 AM   #7
you can get plastic welders on ebay for cheap ($19) that work great; worst case you can plastic weld a patch over the hole. i did something similar when prepping a cayman intake for my car. or, local auto parts stores often sell misc. packs of generic plugs.
Old 11-24-2012, 04:54 PM   #8
sweeper's Avatar
Nitrile rubber plug
The car is resting or I would offer a photo-
I removed my Resonance Chamber a few months ago, cut the plastic tube square and to length, then picked up a rubber plug at Ace Hardware- although it was a nice snug fit, I used silicone and self taping screws to make sure it stays in place. It looks great and is air tight.
Cost- ~$5.00
1997 Boxster- 28k, de-snorked, de-baffled, RSS UD, Dansk "hotdog" sport exhaust.
1985 BMW 635CSI- 30k, 5-speed, LSD
sweeper is offline   Reply With Quote
Old 11-24-2012, 05:27 PM   #9
thank pro hay den dvn.vn de duoc mua hang nhanh nhat, gia ca hop tui tien nhat
nguyenvao525 is offline   Reply With Quote
Old 11-24-2012, 08:00 PM   #10
Jaxonalden's Avatar
Couldn't have said that better myself.
Old 11-25-2012, 04:33 PM   #11
Hey nguyenvao525 and gvtheogiof,
Tới thư rác ở một nơi khác...Diễn đàn saboturds!
Best regards,
Shad
shadrach74 is offline   Reply With Quote
Tags
cold air , evo
