Old 10-01-2005, 07:09 PM   #1
Question 1/4 mile times???
i have a 1999 boxster with tiptronic and no modifications what should my 0-60mph be and what should my 1/4 mile be? also what modifications can i do to gain horsepower without spending too much? and my last question what temperature should i be running at on long drives because today i went for a 45 min drive and it was almost to the line after the 180 mark should it be like that?
porscheguy is offline   Reply With Quote
Old 10-01-2005, 07:21 PM   #2
You've posed a bunch of questions and I can shed some light on a couple of them...
1) performance times... no ideas for you. I bet you can find out by googling "performance specs, 1999 Boxster". It's probably out there some where.
2) "low cost performance mods" is an oxymoron for the boxster IMHO. Exhaust mods start at $1000 and go up. Chip mods don't seem to be worth the price, intake mods can make the car sound better, but can have downsides on your MAF... and the worst part is that some mods to improve HP actually reduce HP!!! I'd invest the money into learning how to drive the car. Join PCA and go to driver's education days. Fun and you'll learn how to shift, brake and turn the car so well that you'll beat other cars with more HP and crappy drivers.
3) Hard driving should produce a temp where the needle is on the "0" in the 180, but not over that middle line. The way to check your system is to get the car up to temp, crank up the AC and then park it idling and walk to the front of the car. You have two radiators in front of both tires and they should both be blowing hot air toward the ground. If only one is blowing, you may have a relay out or a fan out. My 97 had the primary, driver's side fan out. Bearings were just shot and my temp fell to proper ranges when I had it replaced. There are threads on this forum so do a search on "temp" or "overheating" and you'll find it.
Hope this helps!
Hey, I will be in New Braunfels for Thanksgiving this year visiting the wife's family. I would LOVE to meet you and see your car and show you mine if we can hook up. I'm only 15-20 minutes from San Antonio where we're staying. PM me with your details.
Old 10-01-2005, 08:04 PM   #3
A 2.5L will probably be in the mid 6 sec range 0-60 and high 14 sec range in the 1/4. Since your car is a Tip I would add a few 10ths to those times. Like Randall said, I wouldn't invest any go fast mods because you will end up with a much lighter wallet and not be much faster. I would just be happy with what it is or upgrade to an S. The temp sounds about right to me. My car operates at about 180- 185 degrees on the highway and about 190ish in stop and go. 3.2's put off more heat but that is what the 3rd radiator is there for. Maybe 2.5's run cooler though I'm not sure. If your radiator starts collecting a mass of bugs and junk it could cause it to run warm.
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
Old 10-01-2005, 08:27 PM   #4
Forget the mods. Lots of money and NO performance gains! Spend some time learning about the DIY hacks and maintenance. You will learn a bunch about your car and have a little fun too. And...like everybody else said...take a drivers ed course. I need to do this too because from what I keep hearing a good driver will ALWAYS outperform a faster car with your regular everyday driver behind the wheel! Enjoy the car, learn about it, learn to drive it correctly, and you will learn to love the car for what it is...the best all-around performance car on the market!
2000 Porsche Boxster S
2007 Lexus RX350
xclusivecar is offline   Reply With Quote
Old 10-01-2005, 11:26 PM   #5
@Adam,
Go buy a Subaru, you'll be a lot happier in the end...
Happy Motoring!,,,Jim'99
