Old 09-27-2005, 09:24 AM   #1
Jumpy Throttle
I have a 2000 Boxster S with 42,000 miles, here's the deal:
--When shifting from 1-2, or 3-4, etc my throttle blips up a few hundred RPM once I disengage the clutch and start going into the next hear up.
--When in nuetral and I step on the gas a little bit, its almost like the throttle gets stuck a little and over-revs (nothing dangerous but it should stop revving once the pedal is lifted).
--No CEL
Nothing serious, however its is beginning to get a little worse over the past 10,000 miles.
MAF?, dirty Vac hose somewhere??
Any help is much appreciated.
AC
KRZTACO is offline   Reply With Quote
Old 09-27-2005, 03:53 PM   #2
Bump......
Old 09-27-2005, 04:06 PM   #3
deliriousga's Avatar
Is it all the time or just when cold, hot or warming up?
Sounds like the MAF, O2 sensor or vacuum leak. You can try plugging in an OBDII reader that will record the outputs and resistance of sensors and see if anything is strange. That may help in figuring out which it is.
1966 Wife White/Brown Top
Old 09-28-2005, 12:36 AM   #4
Send a message via AIM to blakey Send a message via MSN to blakey
same problem
hi krztaco..........
i have the exact same problem on my 2.7 boxster. if its any conselation to you mine has been doing it for the last 15 months and not got any worse, but i'm as intrigued as you as to what the problem is and what possibly can cure it......
i wait in anticipation
steve........
blakey is offline   Reply With Quote
Old 09-28-2005, 12:13 PM   #5
The throttle happens when its hot and cold.
Anyone............Anyone?????
Bueller............Bueller???????
KRZ
Old 09-29-2005, 07:59 AM   #6
I have it narrowed down to the following:
--IACV
--Throttle housing
KRZ
Old 09-29-2005, 04:27 PM   #7
Hi,
Excuse my ignorance, but isn't the 2.7 Drive by Wire? If so, couldn't it also be a Software issue?
Happy Motoring!...Jim'99
Old 09-29-2005, 05:32 PM   #8
Having a brain fart. IACV=???
Old 09-30-2005, 07:13 AM   #9
My 2.7 has the same issue. I swapped out the MAF but it did not help. I checked for vacum leaks and found nothing. Now I am left with replacing O2 sensors and/or the throttle regulator. Does ANYONE have any experience doing any of these repairs???
psuball1 is offline   Reply With Quote
Old 09-30-2005, 07:33 AM   #10
slogans7's Avatar
Idle Control Valve, I think.
Adam - Maybe something as simple as lubricant on the pedal mechanism?
Actually I'm having a similar problem on my Tip. Shifting manually, in 4th and 5th, I often get a noticable power surge around 3K or a bit under. It almost feels like it's downshifting although it isn't. Odd.
2002 Triple-Black Boxster S
slogans7 is offline   Reply With Quote
Old 09-30-2005, 08:10 AM   #11
[QUOTE=deliriousga]Having a brain fart. IACV=???[/QUOTE
I.dle
A.ctuator
C.ontrol
V.alve
http://www.pca.org/tech/tech_qa_question.asp?id={2FE2DB7F-066E-44BB-86B6-F94296717EDC}
Old 10-16-2005, 05:39 PM   #12
Originally Posted by KRZTACO
I.dle
A.ctuator
C.ontrol
V.alve
A little info (and question) about the IACV. I was recently having a similar problem in the 928 so I started searching the forum for that car to see if I could expect a new MAF, O2 Sensor, or what. Turns out it's the same problem KRZTACO had, but very easy to fix. Several threads on the forum had people (including techs who work on our cars) who popped open the intake hose that connects to the IACV and sprayed WD40 in it. They let it sit for 5+ minutes then reconnected the hose and cranked her up. If it didn't take care of it, they repeated 2-3 times. I did this today and voila, the idle is smooth as silk. Two minutes and $.05 of WD40 was a sweet fix.
So the question is, can this be done with the Boxster? Is there an intake hose like this that is accessible and directly connected to the IACV?
Thanks!
