Old 09-23-2012, 05:13 AM   #1
srad34's Avatar
Front engine mount change
Hi all,
For a while, I have heard creaking from the front mount so yesterday, I got round to changing it.
Once the car was up on ramps, it was a straight forward job. This is the one that came out....(Completely split and has seen better days!)
So, swapped the unit out and fitted the upgrade part and the whole job took just over 2 hours.
The most fiddly bit was moving the coolant hoses to one side to squeeze the mount out (sraying them with auto grease helps here!).
The test drive revealled no odd noises, sharper gear selection and a more positive feel - Awesome
The guides on here really helped and it is a easy job if you are average on the spanners.
It will all end in tears I tell you.......
srad34 is offline   Reply With Quote
