Old 09-17-2012, 03:03 AM   #1
P1124 and P1126, backfires, etc
If anyone is having these problems and have exhausted all solutions check your pierburg vacuum solenoids. Vacuum pump, two test leads, 9v battery. Cap off solenoid feed to device and apply vacuum to valve. Attach power to solenoid. If the gauge drops, the valve leaks and will cause lean run condition. I went through three valves, all leaking. More questions, send a pm.
GoodJohnny is offline   Reply With Quote
