Old 09-09-2012, 10:46 AM   #1
Brake Fluid
Anyone here ever use brake fluid test strips? An indy I know mentioned them to me when I asked about fluid flush recommendations being based simply on time and or mileage. Just curious if anyone has experience with such.
vacarman02 is offline   Reply With Quote
Old 09-09-2012, 11:00 AM   #2
Nope. I don't know what the cost of the test strips are and how old your brake fluid is but, with ATE Super Blue at 15 bucks a quart (you need less than 1 quart to bleed out old fluid and put in new), I would rather do that then to spend it on test strips.
Boxster586 is offline   Reply With Quote
Old 09-09-2012, 01:23 PM   #3
Amazon.com carries them, as do many other outlets, but they are about $50 per container, and they have a shelf life.........
Old 09-10-2012, 07:14 PM   #4
DIY extremist
black_box's Avatar
If you get a motive power bleeder, a complete bleed is gonna take 5 min once you've got the wheels off. Depending on the spoke clearance, you may not even have to take them off, although if you do, it's a good excuse to wax the caliper paint
"Betty" -- 2000 Boxster S, Triple Black, loaded except PSM (sold to a good home)
"Veronica" -- 2008 Boxster S, Arctic Silver on Blue
"Maleficent" -- 2007 Cayman S, Red and Black, TPC Turbo 3.6L 460 RWHP, H&R RSS Coilover / TPC stage 2 suspension
black_box is offline   Reply With Quote
Old 09-11-2012, 09:15 AM   #5
Use your DMM
Instead of buying the test strips, I always check to see if I'm getting conductivity thru the brake fluid by hooking up the negative lead of my DMM to the battery's negative post, and putting in the positive lead of the DMM into the brake fluid reservoir (only touch the fluid) -- look for less than 0.5VDC (less than 0.3VDC is preferred).
You can also use this technique for the coolant to see if you have bad grounds which would cause conductance through the coolant.
Regards,
paul...
paulv is offline   Reply With Quote
