Old 09-05-2012, 05:31 PM   #1
supersparker's Avatar
OBC Upgrade: 2001 Boxster - Not completely successful
After getting a great deal on all of the stuff needed for this project I decided to go ahead and do it. I started early in the day, and took my time as to not damage or miss anything. After a through and methodical several hours, I reconnected the battery only to find less than satisfactory results:
*The check oil graphic comes on and blinks until you press the OBC stalk, then it changes to "000 miles".
*The fuel gauge reads "0" and the "reserve" light is on.
*Turn signals are not displayed on the instrument cluster, and there is the absence of a "clicking" sound when actuated.
*The "low washer fluid" light is on. (washer fluid is not low)
Has anybody had a similar experience?
ANY help is greatly appreciated..
supersparker is offline   Reply With Quote
Old 09-06-2012, 09:02 AM   #2
ppbon's Avatar
It sounds like ....
... you probably have a couple of wires crossed.
Go through the instructions and follow each one of the new wires you added to make sure they are connected properly.
I've done a few dozen conversions and once saw something similar when I crossed two wires.
Happy Boxstering,
Pedro
ppbon is offline   Reply With Quote
Old 09-06-2012, 03:18 PM   #3
Thanks P,
You're probably right. I'll double check my wires tonight.
BTW: I was able to get Moorespeed here in Austin to enable the OBC function...Good shop!
Old 09-06-2012, 06:14 PM   #4
Originally Posted by supersparker View Post
Thanks P,
Pulled everything apart and double checked the wires and they are 100% correct as per the DIY.....
I am at a loss at this point........................
Old 09-06-2012, 06:19 PM   #5
Is there more that needs to be done on the PIWIS programing?
Old 09-06-2012, 06:28 PM   #6
The OBC is either ON or OFF. you still have a wire or two crossed. I did mine a few months ago & it came right up. I turned it on with Durametric. sit back & re-trace your steps.
Bryan topping is offline   Reply With Quote
Old 09-06-2012, 06:44 PM   #7
You can use Durametric to turn it on?
What model year is your Boxster and which version of Durametric did you use?
I have 2001 base.
I have been meaning to do this for a long time.
Thank you.
mikehkang is offline   Reply With Quote
Old 09-06-2012, 08:47 PM   #8
<Resolved>
one of the 3 modex style connectors on the back of the instrument cluster was not fully seated even though the black "cam lock" mechanism was in the "locked position"
After reseating these 3 connectors numerous times, I removed the "cam lock" from the suspect connector pushed it in and it worked..
Old 09-06-2012, 09:06 PM   #9
Wow.
Congrats.
Old 09-07-2012, 08:17 AM   #10
While I was troubleshooting this issue last night the hot water heater located just in front of me ruptured, flooding my work space with about 1/2" of water...
Old 09-07-2012, 11:49 AM   #11
Glad you got it sorted out! http://www.986forum.com/forums/images/smilies/cheers.gif
Old 09-07-2012, 12:22 PM   #12
^Thanks!
Just when I thought it could not get any worse... the hot water heater ruptured about 4 feet from me, flooding the area in which I was working
Putting in a new unit this afternoon.....
Old 09-07-2012, 12:42 PM   #13
^Thanks!
That reminds me, I need to change MY 1999 water heater before it starts to leak.
Good luck with your repair.
