08-23-2012, 05:05 PM
wind deflector fastening levers
i need the levers that fasten the windscreen to the roll bars, i ordered the fstener kit but it is not broken it is the lever on the windscreen itself (need both) are these replaceable? or do i need the wind deflector?
08-23-2012, 05:20 PM
They are replaceable. Local Porsche dealer had them for $5 each. Did mine 2 weeks ago
08-23-2012, 05:22 PM
I don't have a wind screen to look at, but would they be item #10 in this diagram?
Porsche Boxster Wind Deflector And Linings Roll-over Bar Parts
08-23-2012, 05:33 PM
Originally Posted by Spinnaker
Yes that is what i need, I assume they press on?
08-24-2012, 08:02 AM
Also one last question are the parts the same on both sides? the diagram implies that there is only one part so I assume its reversible ..
08-24-2012, 02:47 PM
Yes they press in. I had to carefully drill a piece of the old broken one out. They are also designated right and left. 2 diff part numbers. Hope this helps
09-12-2012, 08:16 PM
top down high speed run
My defletor came loose on the driver's side and started to flap during a high speed top run.....was lucky enough to reach back and grab it before it flew away.
I can tell right away that the lever is broke but I am not sure about the roll bar receptacle.....anyway I need a fix pretty quick
hmmm perhaps not the best photos. So I take it one can replace the levers quite easily and the roll bar suff?? The fit on the driver side is loose when I force it up and down by hand even after locking it...with broken lever and holding it in place
986 00S
09-12-2012, 08:17 PM
what did you drill exactly??
986 00S
09-12-2012, 08:27 PM
wind screen
replaced both in the past ,one on the roll bar one on the deflector, roll bar pad has to be removed , old one drilled out new one riveted in. comes with rivets all you need is a rivet gun and five minutes. my indy didnt even drill old one out he used pliers i bieleve the whole procedure is online. pelican has all the parts cheep
09-12-2012, 09:34 PM
I used three dabs of black silicone (top left, top right, bottom center) to permanently attach the windscreen. It also eliminates the annoying rattles that develop as the fasteners age.
I used the same technique for the headrest grilles after nearly losing one of them on the freeway.
09-13-2012, 10:25 AM
I might consider this thanks....but usually I take all of this stuff off for track days......any thoughts on removal? Vinegar?
986 00S
