Old 08-23-2012, 04:05 PM   #1
wind deflector fastening levers
i need the levers that fasten the windscreen to the roll bars, i ordered the fstener kit but it is not broken it is the lever on the windscreen itself (need both) are these replaceable? or do i need the wind deflector?
dbarnes976 is offline   Reply With Quote
Old 08-23-2012, 04:20 PM   #2
They are replaceable. Local Porsche dealer had them for $5 each. Did mine 2 weeks ago
Msw-986 is offline   Reply With Quote
Old 08-23-2012, 04:22 PM   #3
Spinnaker's Avatar
I don't have a wind screen to look at, but would they be item #10 in this diagram?
Porsche Boxster Wind Deflector And Linings Roll-over Bar Parts
Old 08-23-2012, 04:33 PM   #4
Yes that is what i need, I assume they press on?
Old 08-24-2012, 07:02 AM   #5
Also one last question are the parts the same on both sides? the diagram implies that there is only one part so I assume its reversible ..
Old 08-24-2012, 01:47 PM   #6
Yes they press in. I had to carefully drill a piece of the old broken one out. They are also designated right and left. 2 diff part numbers. Hope this helps
Old 09-12-2012, 07:16 PM   #7
jaykay's Avatar
top down high speed run
My defletor came loose on the driver's side and started to flap during a high speed top run.....was lucky enough to reach back and grab it before it flew away.
I can tell right away that the lever is broke but I am not sure about the roll bar receptacle.....anyway I need a fix pretty quick
hmmm perhaps not the best photos. So I take it one can replace the levers quite easily and the roll bar suff?? The fit on the driver side is loose when I force it up and down by hand even after locking it...with broken lever and holding it in place
986 00S
Old 09-12-2012, 07:17 PM   #8
jaykay's Avatar
what did you drill exactly??
986 00S
Old 09-12-2012, 08:34 PM   #9
I used three dabs of black silicone (top left, top right, bottom center) to permanently attach the windscreen. It also eliminates the annoying rattles that develop as the fasteners age.
I used the same technique for the headrest grilles after nearly losing one of them on the freeway.
sd_boxster is offline   Reply With Quote
Old 09-13-2012, 09:25 AM   #10
jaykay's Avatar
I might consider this thanks....but usually I take all of this stuff off for track days......any thoughts on removal? Vinegar?
986 00S
