Old 09-15-2005, 02:17 PM   #1
Send a message via AIM to series 7
spoiler
is there a way to leave the spoiler up? Any button or what not?
series 7 is offline   Reply With Quote
Old 09-15-2005, 02:25 PM   #2
there is a button that raises the the rear spoiler even when the car is parked. the button is located next to the fuse box underneath the driver's side dashboard. actually, it is near the dead foot rest. good luck!
airbox1 is offline   Reply With Quote
Old 09-15-2005, 03:47 PM   #3
can i always have it up?
Old 09-15-2005, 07:41 PM   #4
Only if you want it to look goofy.
1997 Honda Accord | V6
2004 BMW 330i | ZHP | SOLD
2000 Porsche Boxster | SOLD | http://www.986forum.com/forums/showthread.php?t=9114
http://www.kryzak.com/storage/986sig12.jpg
http://kryzak.tumblr.com
Jeph is offline   Reply With Quote
Old 09-15-2005, 11:19 PM   #5
Send a message via AIM to Richard Truss
LOL. So true. But could porsche put a suckier spoiler on this car? It looks more like a wind brake than a spoiler.
2000 S (3x Black)
Richard Truss is offline   Reply With Quote
Old 09-16-2005, 09:58 AM   #6
Here's an option for a spoiler that's always up. Also fewer moving parts, less maintenance. I pulled the pic from the Porsche pre-owned site - anybody know if this is a factory option???
limoncello is offline   Reply With Quote
Old 09-16-2005, 12:33 PM   #7
That looks like a sample of 986 option "XAA" - Aerokit
Includes front section with integrated front spoiler, side skirts, rear spoiler, and integrated third brake light.
http://i7.tinypic.com/24ovngk.jpghttp://i7.tinypic.com/24ow0id.jpg
06 987S- Sold
Carrara White / Black / Black/Stone Grey Two-tone
05 987 5-speed - Sold
Midnight Blue Metallic / Metropol Blue / Sand Beige
06 MB SLK350- Lease escapee
Iridium Silver Metallic / Black
We've heard that a million monkeys at a million keyboards could produce the complete works of Shakespeare; now, thanks to the Internet, we know that is not true. - Robert Wilensky
SD987 is offline   Reply With Quote
Old 09-16-2005, 01:31 PM   #8
I think that may be a aerokit I wing.
gRed04 is offline   Reply With Quote
Old 09-16-2005, 07:00 PM   #9
I like the slimmer look of he Aero Kit II wing better or the techart option...they both look sleek and lightweight...
Pablito is offline   Reply With Quote
Old 09-16-2005, 07:29 PM   #10
I double the aerokit II wing looks nicer. Anyone know where you can get just the wing?
Old 09-16-2005, 09:08 PM   #11
does anyone have a pic to post of the aerokit II wing?
2000 S (3x Black)
Old 09-17-2005, 01:01 PM   #12
Here's the look of the Aeorokit II and the TechArt one...As far where to get them, aside from the original authorised dealers....well maybe a parts recycler, there are a few specializing in european cars
Old 09-17-2005, 01:22 PM   #13
Thanks -- now which one is which? i sort of like the red car's wing better -- even though it is larger, it seems to fit nicely on the car. also, is there a way to disable the normal spoiler so it doesn't pop-up?
2000 S (3x Black)
Old 09-17-2005, 06:01 PM   #14
The red car is the Aerokit II and the yellow one is the TechArt....to disable the stock spoiler all you need is to take it's fuse out from the fusebox at the driver's footwell....
Old 09-17-2005, 07:40 PM   #15
Here is a better shot of the aerokit II wing.
Old 09-17-2005, 08:00 PM   #16
Brucelee's Avatar
Not a huge fan of wings but that is sweet!
Old 09-18-2005, 01:18 PM   #17
Im thinking about getting the roock spoiler that replaces the stock spoiler, much more aggressive in my opinion.
http://www.roockusa.com/home.htm
Old 09-19-2005, 06:47 AM   #18
just curious - what do the fixed spoilers mount to? Do they generate the same/more/less downforce than the stock? All things equal, the fixed ones make more sense to me -
Old 09-19-2005, 09:53 AM   #19
These drill through the rear deck. I am no expert here but a wing design ( air over and under ) generates both down and up force as the air travels over and under. The standard spoiler doesn't allow any under draft.
On the other hand no flow under equals much more drag ( braking ).
All things considered which one is better? I have no clue.
I sure like the look of the wing much better and I am planning to add one in the near future. I think I will leave the factory one active unless I notice some negative performance issue with the combination.
Old 09-19-2005, 11:46 AM   #20
Hi,
If you want to keep the spoiler up all the time, raise it manually and then pull the Fuse!
So far as the Aftermarket Wings, these are very different from Spoilers. They really aren't 'Wings' at all, they're much more like Ailerons. A 'Wing' uses the motive force of the Car (Engine) to Push the Air out of it's way. Since Newton's 2nd Law of equal and opposite reaction is present, an equal amount of reverse force is exerted on the Wing pushing the rear end down, just like the Ailerons on an Aircraft.
A Spoiler operates under a completely different priciple. An actual Wing doesn't really create Lift, that is a misnomer. Air flowing faster on one side of a surface than another experiences a Pressure Drop (Bernoulli's Principle). A Wing works because the air on the upper (or curved) surface flows faster and so has a lower Pressure and actually Sucks the Wing upward. The airflow going over a Boxster moves faster at the rear of the Car than the air flowing underneath it, so it sucks the rear upward. By slowing this air down, or, Spoiling it, the negative pressure it exerts on the rear of the Car is reduced.
So a 'Wing' actually Adds a Force to the equation, while a Spoiler removes, or prevents it. Hope this helps...
Happy Motoring!...Jim'99
PS A Partial Vacuum creates quite a bit of Drag (robbing power and speed), by using the Spoiler to cleanup the Airflow on a Boxster, the Cd (Coefficient of Drag) is actually reduced by an additional 0.4 according to Porsche. A 'Wing' on the other hand would create quite a bit of additional Drag on the Car.
