Old 08-20-2012, 06:46 PM   #1
Help with engine code pls.
So today when starting up the car up for work I get a very rough idle..
engine light starts flashing so I check the codes.
Engine idle smooths out .
Code reads p0300, p0304, p0305, p1319, p1317 p1316.
I clear the codes. Car drives fine no lose in power.
Sometimes rough idle on start up but that's it.
The idle smooths out after about 30 secs.
97 50k miles,
Just had the coolant tank replaced and water pump and drive belt replaced as well.
Any help guys?
SF-Rockster is offline   Reply With Quote
Old 08-21-2012, 07:28 AM   #2
PM sent
SF,
Sent you a PM.
Regards,
paul...
paulv is offline   Reply With Quote
