Old 08-18-2012, 03:57 AM   #1
WV Boxster
wvboxst3r's Avatar
Found a problem now the fix
Need help, had car up on a lift and first time for me under it. Noticed a (sensor) out of place. I could not get a picture but the tires shop had a mechanic and he looked at it. His thoughts was a suspension sensor, ride adjustment. It was not minted just tucked in under the rear axle. The wire was rubbing the axle and has left a small groove.
The sensor is connected to car by a 8" bar going to a knuckle then a 1" bar to another knuckle then the sensor. We moved it around and the only place that the bolt hole would line up was above the the rear axle on the frame this is on the drivers side.
Does anyone have a diagram or picture of the suspension area for me to reference?
If your not LIVIN now, then when?
wvboxst3r is offline   Reply With Quote
Old 08-18-2012, 05:15 AM   #2
2001 Arctic Silver 2.7
tony_fury's Avatar
Could be the wire to the rear brake contact sensor?
Here's a link.. Could it be item #7
Porsche Boxster Disc Brake Parts
RMS, IMS, 87.5K
Old 08-18-2012, 06:09 AM   #3
Porsche Boxster Rear Axle Parts
http://www.********************************************.com/porsche-parts/986-97-04/501-01.php
MY?
and do you have factory litronics?
Old 08-18-2012, 03:05 PM   #4
landrovered's Avatar
Headlight height adjustment sensor.
2001 Boxster S 3.6L, Zeintop
"Calling upon my years of experience, I froze at the controls." - Stirling Moss
landrovered is offline   Reply With Quote
Old 08-18-2012, 04:04 PM   #5
WV Boxster
wvboxst3r's Avatar
Originally Posted by Burg Boxster View Post
Second link parts 18 thru 22.
I have a 2000 with factory litronics. From the diagram and landrovered it looks like a sensor and I guess headlights. What a place for them. It has been in the wrong place since I owned it. How does this work in with the headlights.
