Old 08-18-2012, 04:57 AM   #1
wvboxst3r
WV Boxster
wvboxst3r's Avatar
Found a problem now the fix
Need help, had car up on a lift and first time for me under it. Noticed a (sensor) out of place. I could not get a picture but the tires shop had a mechanic and he looked at it. His thoughts was a suspension sensor, ride adjustment. It was not minted just tucked in under the rear axle. The wire was rubbing the axle and has left a small groove.
The sensor is connected to car by a 8" bar going to a knuckle then a 1" bar to another knuckle then the sensor. We moved it around and the only place that the bolt hole would line up was above the the rear axle on the frame this is on the drivers side.
Does anyone have a diagram or picture of the suspension area for me to reference?
If your not LIVIN now, then when?
wvboxst3r is offline   Reply With Quote
