Old 08-15-2012, 03:25 PM   #1
Steering shake after alignment
After the full suspension overhaul, bearing change, tie rod change etc I took the car in for a full alignment and road force balancing to a local Porsche shop. After the alignment and balancing the front wheel vibrates and I can feel it in the steering. The front also feels like its kind of uncontrollable at high speeds (75+). Almost like its got no grip.
The steering never vibrated even after the suspension overhaul work except it was cocked to the right side which I attribute to not putting back the tie rod to original mark. They said they did it to factory specs and asked me to bring it back in.
Question is: what specs should I have it aligned to? Normal street driving is what I do.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
Old 08-15-2012, 03:47 PM   #2
Johnny Danger's Avatar
Did this service involve getting new tires ?
Old 08-15-2012, 04:48 PM   #3
Did you drive the car at speed after the suspension rebuild and no shakes? If not, then I would say something is loose in the new suspension.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 08-15-2012, 05:17 PM   #4
No. Same old tires.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
Old 08-15-2012, 05:20 PM   #5
Yes. I did drive the car at hogh speeds after the rebuild. I had torqued them all to spec as well. You may have a point on something coming loose but, this shop is well known Porsche so I assume they did the right things. I was even watching from far and can't complain about how they went about the whole process.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
Old 08-18-2012, 12:33 AM   #6
Bruce Wayne's Avatar
1. check the wheel weights - have you lost a weight and they are out of balance
2. check the tyre wear across the face is it even ? if you have worn shoulders after alignment it could cause vibration.
3. are the tyres worn consistently and evenly round
4. is there any tread demlaination on the tyres or flat spots
986 x2 6sp
2x Range Rover Vogue 4.6
2004 MX5 Sport 6speed Strato Blue (wifelet)
2x Range Rover Classic & CSK
Bruce Wayne is offline   Reply With Quote
Old 08-18-2012, 04:43 AM   #7
WV Boxster
wvboxst3r's Avatar
My guess is flat spots on tires. Had mine up yesterday and noticed the inside of the front tires was cupped or flat in spots. When I mentioned this to shop I was told that was from the toe out and not pushing the car on all corners. So I may have some of the toe adjusted and buy new fronts because the car would shake bad with these tires.
If your not LIVIN now, then when?
wvboxst3r is offline   Reply With Quote
Old 08-18-2012, 09:25 PM   #8
Thanks Bruce and WV. Good points. Will check it out. It may be time for new tires after all.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
