Old 05-08-2003, 09:48 AM   #1
Transmission Fluid
What weight is recommended to use for my 1998 Boxster? I want to use synthetic but would like to know both synthetic and original if they are different. Also where is the plug for the drain and refill?
Yoslack is offline   Reply With Quote
Old 05-09-2003, 05:39 AM   #2
The specifications are in your owners manual. You have you remove the metal plate that is shaped like a triangle to get to the drain plug. You also need the correct allen wrench/bit to remove the fill plug, and a special anti-tamper triple square bit to remove the drain plug. I happen to have these bits. Jeff
Tool Pants is offline   Reply With Quote
