Old 07-18-2012, 05:37 PM   #21
Jager's Avatar
This is turning-out to be a fun thread! I hope you don’t have any valve damage. I’m curious to see what Jake asks you to do as he walks you through this. Keep the pictures coming!
Jäger
300K Mile Club
Old 07-18-2012, 05:52 PM   #22
Engine Surgeon
Ok... Just as I suspected. You need to check for collateral damage now. Do you have a leak down tester?
If the valves aren't bent, I have a fix for this. If the valves are bent, or even the pistons screwed, I have a fix for that too. Hell, we pray for a failure like this, everything we have had lately looks like this.
US Patent 8,992,089 &
US Patent 9,416,697
Old 07-18-2012, 06:45 PM   #23
If you don't have a leak down testor you can improvise with this little trick, hook up your compressor to it and listen in the exhaust and intake for leaks.... you can also lay paper over the in/ex opening to see if any physical movement....
Just make sure you don't seal the hole through the center...
98 boxster
82 280sl parts for sale
feelyx is offline   Reply With Quote
Old 07-18-2012, 07:00 PM   #24
Engine Surgeon
Pull the cams first.. Otherwise you will have valves that are held open and will give a false indication.
US Patent 9,416,697
Old 07-18-2012, 07:16 PM   #25
It good to know that no matter what you have a fix. As for the leak down tester no i dont have one. Just a compression tester.
edwardneff94 is offline   Reply With Quote
Old 07-18-2012, 07:21 PM   #26
I will see about building one tomorrow after work. My compression tester has an air fitting where the dial hooks on so i will see if that might work also. Thank you again for all your help.
Old 07-18-2012, 07:22 PM   #27
Engine Surgeon
With a compression tester kust pull the schrader valve out so air will pass the opposite direction and you are good to go.
Pull the cam assemblies..
US Patent 9,416,697
Old 07-19-2012, 03:45 PM   #28
Todays update, I just finished testing each cylinder and here are the results, cylinder #1 gave me a nice cooling breeze from the intake, while cylinder #2 helped to beat the 105 degree heat with a breeze from the exhaust, cylinder #3 was the only one that did not have a leak.
Pic of test on cylinder #2
Plugs from left to right, #3,#2,#1
Old 07-19-2012, 04:51 PM   #29
Did you tap on the valves to make sure there is nothing stuck under them? Chances are they are bent... but you never know........
98 boxster
Old 07-19-2012, 05:48 PM   #30
Jager's Avatar
I would test the other side too.
Jäger
300K Mile Club
Old 07-19-2012, 05:55 PM   #31
Engine Surgeon
Exactly what I expected.. Do you know how many shops would not have done this test and tried to repair it without pulling the head?
It sounds like it needs to come see the magicians:-)
As long as you didn't hear air in the crankcase we are still in business.
US Patent 9,416,697
Old 07-19-2012, 07:10 PM   #32
I did not hear any air in the crankcase, I have bags over all the hoses and open ports in the engine to keep junk out, none of the bags showed any sings of air so i hope that is good news. Thank you for taking the time to talk to me today and for all your help throughout this process. I will call you and try to figure out when i can get it out to you.
Old 07-19-2012, 07:48 PM   #33
Engine Surgeon
That's great. Glad to help. Dean can work with you on getting the engine shipped, he got a shipping quote today.. I'll do my part once the engine gets on deck here.
Heck, I might even post all the pics of this one here..
US Patent 9,416,697
