Old 07-13-2012, 01:48 PM   #1
Opposed to Subie Burble
Overdrive's Avatar
Indeed, hence why I said if it's functional (wired up), then all one would need to do is get the computer activated and away you go, much in the same way that someone can use one of the switch blanks on the center console to install a switch that cycles through the OBC's functions, no 4th stalk needed.
-O/D
IMSR + RMS
Robbins glass window top
Old 07-13-2012, 08:42 PM   #2
OBC Question
Thank you.
jrblackman is offline   Reply With Quote
