Old 07-07-2012, 05:21 PM   #1
What is this and how do ( or should) I fix it?
I did a good off the ground look around my new Boxster and this is broken off and would like to know what it does. An more so do I need it fixed? It is located in the forward left tire well just aft of the control arm.
Thanks Thom
Perrytbiii is offline   Reply With Quote
Old 07-07-2012, 06:23 PM   #2
LAP1DOUG's Avatar
I just checked, and I don't have one of these on my car, and it works just fine. The Litronic headlight aim controller has an actuator that looks like this, but I took mine off when I changed to GT3 control arms, so I can't be sure. I just used some safety wire to fix the litronic sensor arm in the middle of it's range, if that helps you any.
Kippis
986S
991S
Van Diemen RF97
LAP1DOUG is offline   Reply With Quote
Old 07-09-2012, 05:14 AM   #3
DIY extremist
black_box's Avatar
That's the suspension angle sensor for the Litronics headlights. Mine was broken too, so I ziptied it into the hole in the control arm and it's worked fine since.
"Betty" -- 2000 Boxster S, Triple Black, loaded except PSM (sold to a good home)
"Veronica" -- 2008 Boxster S, Arctic Silver on Blue
"Maleficent" -- 2007 Cayman S, Red and Black, TPC Turbo 3.6L 460 RWHP, H&R RSS Coilover / TPC stage 2 suspension
black_box is offline   Reply With Quote
