Old 06-11-2012, 10:25 PM   #1
Brake wear indicator
A few weeks back I took my 99 Boxster to my first HPDE. Everything went well, and had a great time. However on the second to last run, as I began to get slightly more aggressive in my braking, the brake wear light came on.
I ducked out the run to make sure there wasn't a huge issue. I visually checked and it looked like plenty of pad material left, so I went ahead with the last run.
Ordered new pads when I got home and when I went to put them on, the pads that were on the car were just about the same thickness as the new pads. It seems the front wear sensors got too hot from braking and kind of melted, and triggered the dash light.
I went ahead and did all the pads and all new sensors, but was wondering if this was a common issue. If you regularly track your car do the wear indicators give you problems?
Botoxster is offline   Reply With Quote
Old 06-12-2012, 04:41 AM   #2
Most people that track their cars disconnect the wear indicator from the pad and zip tie it to the hard brake line to avoid what happened to you.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 06-12-2012, 10:09 AM   #3
Joel-Box-ster's Avatar
I also get the "Brake Wear" dash light every once in awhile, but I dont track my car and front and rear pads are still thick..
2K Boxster White/Grey Int./Hardtop/TIP
Joel-Box-ster is offline   Reply With Quote
Old 06-12-2012, 10:25 AM   #4
See this thread: Melted Brake Sensors
If you track the car, remove the sensors from the pads and tie back using a zip tie. Just remember to manually check your pad wear.
Old 06-12-2012, 10:14 PM   #5
Thanks everyone for the prompt replies.
