Old 05-07-2012, 11:49 AM   #1
2002 Boxster
Instrument Cluster (S on a Base)
Can I install an S instrument cluster on a base ? (both Tiptronic, both 2001)
Terry
TerryT is offline   Reply With Quote
Old 05-08-2012, 08:23 AM   #2
2002 Boxster
Originally Posted by TerryT View Post
Terry
Well I've ordered it... so I will know soon enough.
Old 05-08-2012, 10:07 AM   #3
2003S's Avatar
I don't think you'll have any problems since they are both the same year -- I believe there are 2 versions of the cluster one for 2000 & earlier, one for 2001 & later.
I'd have considered a 996 cluster to get oil pressure...
2003 Midnight Blue S
LN IMS Retrofit
Old 05-09-2012, 06:11 AM   #4
2002 Boxster
How does the odometer get changed when a new instrument panel is installed ? Can the PTS2 do it ?
Old 05-09-2012, 06:44 AM   #5
I think.... the odometer is stored in the brain not the panel. It shouldn't matter.
sean
Old 05-09-2012, 06:48 AM   #6
Got to thinking about it... I may be wrong...
http://986forum.com/forums/general-discussions/11501-if-you-replace-gauge-cluster.html
Old 05-09-2012, 12:29 PM   #7
2003S's Avatar
Wayne's write up gives you a "yes" on needing a PTS2 to update the mileage on the ODO, and you have to do it within 50 miles of the change:
Pelican Technical Article: Boxster 996 Gauge Cluster Upgrade - 986 Boxster (1997-04) -
LN IMS Retrofit
Old 05-13-2012, 10:51 AM   #8
ChrisZang's Avatar
Palo Alto Speedometer does it for $150
