Old 04-24-2012, 08:50 AM   #1
squirdle's Avatar
Battery/alarm problem
I am trying to replace the battery on my 986. When I disconnect the negative lead, after about 5 seconds, the alarm sounds for 30 seconds (hell, that thing's loud!). It continues to sound even if I disconnect the positive. I can't find any reference to this anywhere. Is it possible to do something to prevent the alarm activating when changing the battery, or am I just going to have to deafen myself and annoy the neighbours?
squirdle is offline   Reply With Quote
Old 04-24-2012, 09:39 AM   #2
1999 base
Meir's Avatar
someone probably installed an aftermarket alarm in your car. the OEM alarm system is connected to a horn located next to the battery, and doesn't have any alternative power source.
Old 04-24-2012, 05:36 PM   #3
WV Boxster
wvboxst3r's Avatar
If you can't silence the alarm then put a battery charger on the battery leads and the car should not notice that the battery is out of the car.
If your not LIVIN now, then when?
wvboxst3r is offline   Reply With Quote
Old 04-25-2012, 03:22 AM   #4
This is a very bad idea, most chargers are high current (amperage) out put, and there would be no battery to absorb the current. You could do some serious damage.
There are maintainers that have low current settings specifically for doing this, but not all do............
Old 04-25-2012, 04:20 AM   #5
WV Boxster
wvboxst3r's Avatar
Mine has a 2amp setting. That is what has been used for years and many cars. Didn't think about the cheaper versions of chargers.
Nice job JFP.
Old 04-25-2012, 01:45 PM   #6
squirdle's Avatar
fIXED
Found out that before removing battery leads, put key in ignition and turn to position 1. It works. New battery installed in perfect peace.
Old 07-16-2012, 02:00 PM   #7
Christian H's Avatar
I had similar issues when changing my battery but I think it's only the European Boxster's that require the ignition turned to position 1 (auxiliary battery back up)
It's pretty loud with your head under there isn't it!
Christian H is offline   Reply With Quote
