Old 05-27-2013, 11:50 AM   #7
Bad pinion bearing on a 6 speed gearbox..?
Over here, good used Boxster transmissions are only running $400-$500 ea. My Spec Boxster racing friends have 2-3 spares each. When one fails, they just swap in a replacement. Broken units are sold for scrap since it costs more to rebuild (~$1,200) than to replace.
It seems that the pinion bearing on my 6 speed tranny is failing (the differential has excessive noise when you unload it at low speed), a friend that specializes on P cars told me that you need a press with 40,000lbs capacity (..!) to replace the bearing...
I am planning to remove the pinion shaft, by any chance do you know where can I take it to get the bearing replaced?
