Old 04-05-2012, 11:47 AM   #1
Originally Posted by stateofidleness View Post
wow... hmm... what "special" tools are needed? i found some DIY's online, but either pics are lacking, it's for a manual, or there's a bunch of Porsche tools needed for the TIP. What's the best DIY available for this?
Because you are literally filling the Tip trans through a port in the bottom of the pan, you need some type of pumping device, a hose with an inverted "J" end on it, and some ingenuity. These shots are a Tip in an Audi, but it is the same gearbox. You don't need to have the very best stuff to do it, as you can see from the third picture, but good equipment does make it easier. Motive makes a tool to do this.
