Old 02-21-2012, 06:30 PM   #1
2000 S: Horn Doesn't work when ignition 'On', works when 'Off'?
Horn works when ignition 'Off', doesn't work when ignition 'On'? I have wiring diagram and already confirmed 25A fuse B3 is good, and relay 10 is good. What can I try next (replacing ignition is out of the question to solve a horn problem)?
rujorujo is offline   Reply With Quote
Old 02-26-2012, 04:27 AM   #2
I just went through this problem, exact same symptoms, horn works with no key, does not work when car is running. ..dealer replaced "clockspring" and airbag control unit in steering column....$675....ouch
newt is offline   Reply With Quote
Tags
horn , wiring
