01-26-2012, 03:21 PM
Good Question: Why did Porsche..
Porsche **only** used the oil pipe on the left for the M97 2.7 and 3.4 engine in the 987 and 987C
The M96 3.4, 3.6 and the M97 3.6 and 3.8 utilize the same oil return pipe as the 2.5/2.7/3.2 Boxster engines.
What gives? Why change only on the mid engine late cars?
I know what it does.. and I know which one **technically** should work better
Anyone out there "know" why they did this?
B
01-26-2012, 05:57 PM
WV Boxster
no clue but I am chiming in to not miss answer
If your not LIVIN now, then when?
01-26-2012, 06:03 PM
I was all excited when my email "dinged"..
The canister version on the right helps to get the air out of the oil before it returns to the oil pickup area.
The one on the left would help promote getting the oil back to the pickup sooner, but it would have more air in it.
What did they learn? Why did they only use this method on the 987's?
B
01-26-2012, 06:04 PM
Sad..
I just noticed all the GT3 shims on my desk in that picture.
I'll do a better job of cropping my pics
B
01-26-2012, 06:54 PM
Registered Boxster abuser
Originally Posted by Brad Roberts
Sad..
B
At least you don't have a box of tissues and a reflection of something indecent on your monitor...
01-26-2012, 06:57 PM
That is a good point
Floating around on the web somewhere is a picture of a naked guy reflection. he was taking a picture of his couch for eBay.
I personally have not seen it..
B
01-26-2012, 07:08 PM
Well I purposely kept the old style in my sump, as I had heard of Cayman guys retro fitting the older style swirl pots to reduce foaming. Had holes put in my windage tray.
Sounds like change had something to do with engine placement. Perhaps oil return speed in the mid engine location was found to be dominant/more important than taking time to defoam. Perhaps foaming was found to be a predominantly rear engine problem .....something to do with the dynamics of the car
986 00S
01-26-2012, 06:20 PM
B
To prevent oil starvation?
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
01-26-2012, 06:25 PM
That is my best guess, but why would they not use the same part in the 3.8X51 engines? Both have the same oil pumps, or the 3.6?
B
01-27-2012, 02:02 PM
So Brad, don't keep us hanging. Enquiring minds want to know.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
01-27-2012, 02:51 PM
I honestly don't know
I know which ones I'm going to use...
B
01-27-2012, 04:20 PM
Ok, I'll bite. Porsche has had a problem (that I've heard of, mostly with Caymans) with 987 motors developing cylinder and piston scoring in cylinders 4-6, leading to engine replacements under warranty. Thinking that the problem was oil starvation, Porsche got rid of the swirl pots and just dumped the oil directly into the sump with the straight pipe.
For what its worth, Hartech argues very pursuasively that the problem is not oil starvation, but overheating caused by a revision to the head gaskets which makes them cheaper, but which leads to higher temps in the 4-6 banks, especially cyl 6, which is compounded by the Porsche coolant thermostat that runs at too high a temperature.
http://www.hartech.org/docs/buyers%20guide%20web%20format%20Jan%202012%20part% 205.pdf
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
01-27-2012, 07:12 PM
I'm buying some of it, but not all of it
The 3.4 CaymanS block is the same block as the 3.4/996 and 3.6/996
I'm reading..
B
02-02-2012, 01:54 PM
Ahh it's all in here!
986 00S
01-27-2012, 07:29 PM
the sofa came after the tea kettle...
**NSFW**
snopes.com: Indecent Exposure
01-28-2012, 04:04 PM
Both of these are 3.4 Head Gaskets. The top one is 996 3.4, the bottom one is 3.4 CaymanS
The 996 3.4 has the smaller holes for the water passages, the CaymanS has the larger.
Technically the water for a 996 has to travel further prior to entering the engine after the radiators.
01-28-2012, 04:05 PM
I do have a 3.4 CaymanS block with cylinders 5+6 bad
B
02-02-2012, 01:45 PM
It looks like the 996 head gasket has some kind of flow control orifice function where the 987 does not. One hole is really small. Sooo if they are the same blocks then this would make a difference in what heat transfer occurs via the coolant yes?? Both are putting out the same power; same oiling system; same torque; same water pump.
I am not sure what advantages 996 rad distance would give...got to think about that
Are there Cayman guys that gave swapped in the 996 head gaskets? Are there differences in the heads particularly the coolant passages?
986 00S
02-02-2012, 01:59 PM
Originally Posted by jaykay
It looks like the 996 head gasket has some kind of flow control orifice function where the 987 does not. One hole is really small. Sooo if they are the same blocks then this would make a difference in what heat transfer occurs via the coolant yes?? Both are putting out the same power; same oiling system; same torque; same water pump.I am not sure what advantages 996 rad distance would give...got to think about that
Yes, the hole differences are for coolant flow control. Cyl 6 is the hottest, since it is furthest away from the WP, so on the 996 HG, 6 has the biggest hole for extra cooling. 996 HG are not interchangeable left to right banks. For the 997, Porsche decided to save a couple of bucks and made the HG interchangeable, but to do so, had to equalise the coolant flow orifices. According to Hartech, the refised HG is why Caymans experience left bank cylinder failures.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
