01-22-2012, 03:03 PM
What is wrong with my clutch pedal?
Hi all,
I recently purchased a 2003 Boxster S with about 34000 kms on the clock (that's 21000 for you weird imperial types).
When I press the clutch pedal in it moves smoothly, but when I release it, it feels a bit rough and 'grabby'.
Any ideas what it could be? I am hoping it just needs the cylinders bled, or perhaps the master/slave cylinders have broken a seal... but I'm completely talking out of my arse.
I'm presuming it isn't an issue with the clutch/pressure plate given the low mileage, but I have no idea how the previous two owners drove it.
Any advice would be gratefully received!
01-22-2012, 03:23 PM
Autobahn Glanz
Not sure what rough and grabby is in this situation. Do you mean the engagement is grabby? Or the peddle itself doesn't release back smoothly? Is it grabbing on the floor mat?
01-22-2012, 05:31 PM
The pedal travel doesn't feel smooth. I'm fairly sure it's not grabbing on the mat but I'll remove the mat and check.
If I feel the same roughness in the travel with the engine off, that should eliminate the clutch disc and associated bits as the source of the problem, yes? No?
01-22-2012, 05:35 PM
Autobahn Glanz
I thought the clutch was like brakes...engine on or off it still works the same.
01-22-2012, 05:40 PM
I'm with Whip350, I think it is the same either way (or at least feels the same to me).
SOLD 2001 Boxster S, Arctic Silver, Painted Bumperettes, De-Ambered, Chrome Badging and Emblems
[No longer active on this forum]
01-22-2012, 06:08 PM
But with the engine off the flywheel isn't spinning, so you'd be eliminating roughness from a cracked or bent component...?
01-22-2012, 06:09 PM
Clutch Judder?
2001 Boxster S 3.6L, Zeintop
01-22-2012, 06:18 PM
Autobahn Glanz
Maybe throwout bearing...but then you would feel it pushing in too. It sounds like your are describing a feeling coming from the actual clutch and not the pedal or master/slave cylinder.
If there is even a slight bit of air in the system that will make the clutch feel funny at the top on release or it may not even release all the way, doesn't sound like you are describing that.
Maybe Landrovered has it right, but I'm not familiar with that unless it means the clutch is worn out.
01-22-2012, 06:39 PM
"Clutch Judder is caused by the clutch components and flywheel not meeting concentrically. The friction surfaces rub concentrically causing a low frequency vibration that is transmitted to the car via the engine/gearbox mountings and drive shafts."
But if the engine isn't running, that can't be the issue.
I'm only about 90% sure I feel it without the engine running, so I need to check again when I get home.
01-22-2012, 06:45 PM
Define 'funny' - this feeling doesn't happen through the entire pedal travel. I'm going to clutch at this straw and presume there's air in the system and try bleeding it.
01-22-2012, 07:00 PM
Autobahn Glanz
There will be a delayed full release at the top or it won't release all the way at all, this is often felt when bleeding the clutch and one hasn't got all the air out. I think if this were it it would be obvious to you.
I've bled my clutch twice, once when I got the car, need monkey arms to do it. I have a power bleeder so that helps. It went well. Then the second time when I replaced my clutch and slave cylinder. When I finished it the second time it felt like there was still some air in it because it seemed like the clutch wasn't releasing all the way at the top...but it clear up and works like a charm now.
Maybe one of the experts will jump in and help out...
01-22-2012, 11:30 PM
Ah, I get what you mean now. Yes, I've felt that on some cars in the past.
I feel a bit silly now as when I came home to test the car with the engine off the problem had vanished. Started the car up and it wasn't causing problems (only in neutral though). If it happens in gear I'll know I have a big bill coming up.
02-18-2012, 02:20 AM
A follow up: I'm now hearing serious creaking coming from the clutch pedal area when I press the clutch down. I suspect it's the assist spring and will try lubricating it soon. Just thought I'd add this in case others have similar problems in the future.
02-19-2012, 04:50 PM
Thanks for sharing, and welcome another Melbourne Boxster!
Sam
Australian Carbon Fiber nut
02-19-2012, 04:51 PM
I'm from Geelong actually...
Sam
