01-15-2012, 12:55 AM
Squeak behind seats?
On my Porsche Boxster S 986 There is a persistent squeak behind my head. Could it be the retractable hood mechanism or something to do with the engine mounts?
01-15-2012, 01:42 AM
I had a squeak that turned out to be the passenger seat back rubbing on the roll bar. Moved the back rest foward eliminated it.
01-15-2012, 03:16 AM
Thanks, but...
Thanks for the idea, but I tried this first and the squeak continues.
01-15-2012, 05:52 AM
Do you have the wind deflectors? They usually rattle in the rollbar hoops, but I guess they could squeak as well.
01-15-2012, 05:53 AM
Or could the squeak actually be more of a squeal? From one of the pulleys on the drive belts?
01-15-2012, 12:47 PM
Nah, thanks, but the squeak is not linked to the wind deflector and it isn't a drive band etc.
01-15-2012, 03:20 PM
I too have a squeak and its from the passenger side I think and its like rubber on rubber so it is a "squeak". I was wondering about lubricating or cleaning all the rubber seals etc in the top/window area and see if that helps.
2006 Hummer H3 - RED 76k mi - LIFTED - 3rd row custom seating on 35's and a manual tranny.
1997 Boxster Guards - RED 86k mi - 19" Lobster Claw Wheels on Conti's , Porsche side decal for extra "speed", manual tranny -signed by Hurley Haywood
Phoenix, Arizona
01-15-2012, 04:21 PM
Autobahn Glanz
I thought everybody had squeaks with the top up. I haven't tried too hard to find it, maybe I should and lubricate it. Mine is definitely some joint or two parts of the roof structure rubbing on each other.
01-15-2012, 04:25 PM
I have 2, seatback rubbing and sun visor (sounds like ...in the back ?)
01-15-2012, 07:41 PM
My sun visor rattles sometimes, but no squeaks from my top.
01-16-2012, 08:32 AM
I didn't have these squeaks until i removed the engine bay cover and put it back. I am riding right now with out the carpets and i am presuming that its the engine cover that is squeaking. So i will let you know when i take a look at it, mean while check it out.
01-16-2012, 01:31 PM
ok so i took a look at my engine cover and yes its squeaking. So i can say that if the squeaks are not coming from the seat then its the engine cover that is not properly seated or something along those lines.
01-16-2012, 03:16 PM
This stuff is the cat's meow for rubber seals.
eShine Canada: 1Z Einszett Rubber Care Stick Gummi Pflege (3.4oz)
01-16-2012, 06:01 PM
Originally Posted by ekam
Anything like this in the states? Would love to give it a try.
Phoenix, Arizona
01-17-2012, 10:53 AM
so I removed the engine cover and put it back made sure it was seated properly and the squeak was gone. I sugest trying this if anyone has a squeak that isn't the chair, and is coming from behind the chair.
01-17-2012, 12:27 PM
Cool. I will try this first.
Phoenix, Arizona
01-21-2012, 07:19 PM
Matt
It could be the loose nut behind the wheel...
Matt
2004 Boxster S, Guard's Red, 6 Speed
01-21-2012, 11:18 PM
Originally Posted by Spinnaker
I had a squeak that turned out to be the passenger seat back rubbing on the roll bar. Moved the back rest forward eliminated it.
Same here, bugged me for ages until someone got in and moved the seat forward, Doh!!
Guvs.
