Old 12-27-2011, 06:26 AM   #1
truegearhead's Avatar
loosing power, stumbles at high RPMS? Ideas?
My car has started loosing power and stumbling every now and then at higher RPMS. Sometimes it will start off with no power and then snaps back to normal. It seems like a fuel issue any ideas?
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
Old 12-27-2011, 06:43 AM   #2
Christian H's Avatar
I had similar issues turned out to be Maf sensor and a couple of cracked coil packs after they were changed all was well again.
Christian H is offline   Reply With Quote
Old 12-27-2011, 07:20 AM   #3
oh good so nothing expensive....sigh.
Was your car throwing a code? Mine is not which makes me think its fuel delivery and not the maf sensor or O2 sensor. Or thats at least what I keep telling myself.
2003 911 C2
Old 12-27-2011, 07:27 AM   #4
No everything was totally normal the car just felt as though it was hesitating and stuttering (it was a strange feeling) when near to the red line, I thought it was fueling issues until I had it checked out at my local independent
Old 12-27-2011, 07:49 AM   #5
Track rat
Topless's Avatar
Disconnect your MAF sensor and drive the car. If it runs better, replace the MAF.
Old 12-27-2011, 09:51 AM   #6
Start with the basics: Fuel, air, spark.
Fuel pressure ok? Fuel pump.
Air mixture ok? MAF.
Spark ok? Plugs/Coil packs.
Old 12-27-2011, 07:09 PM   #7
Steve Tinker's Avatar
When was the fuel filter last replaced?
2001 MV Agusta F4.
Old 12-27-2011, 07:56 PM   #8
Porscheectomy
It sounds like an issue with a spark plug or coil.
