Old 07-17-2005, 07:37 AM   #1
Brucelee's Avatar
Oil consumption and Mobil 1 Black Top
Many of you may know that the early Boxs and 911s came with Mobil 1 15-W50 (redcap) and that was known as "factory fill." Later Mobil developed their 0W-40 (black cap) and that became factory fill.
I know that many have complained about oil consumption in the Boxster engines. My service tech says that 1 qt per 1000 miles is "normal,.
Here is something interesting. I have used redcap in my wife's car for some time. NO oil consumption between changes. Recently, I switched to blackcap and lo and behold, I am using about 1 qt per 1000 miles in her car.
Hmmm, what do you make of this??????????
Of course, here in SOCAL, I can use either due to our climate. This may not be germane for many of you.
Old 07-17-2005, 11:38 AM   #2
Good question! I don't know what to make of it myself, but I too have driven my car about 2300 miles since I bought it used, and no oil consumption either. If 1 quart every 1000 miles is "normal", is no consumption "abnormal"?
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
bigislandboxster is offline   Reply With Quote
Old 07-17-2005, 01:37 PM   #3
ddb
www.klisstle.com
ddb's Avatar
I haven't put enough miles on my 2000 Boxster since I've had it to determine oil usage. I am running the 0W-40 and am interested to see what happens. 1 quart per 1000 miles sounds like high consumption to me. Doesn't it sound excessive if one would have to add 15 quarts over the course of a year beween oil changes? This is, of course, if a car was driven 15,000 miles a year and the oil was changed every 15,000 miles.
ddb
Old 07-17-2005, 05:28 PM   #4
Brucelee's Avatar
"Doesn't it sound excessive if one would have to add 15 quarts over the course of a year beween oil changes? This is, of course, if a car was driven 15,000 miles a year and the oil was changed every 15,000 miles."
My thoughts exactly. Wouldn't this obviate the need for an oil change????????????
Old 07-17-2005, 08:48 PM   #5
Rail26's Avatar
obviate? I had to look that one up.
'05 987 Basalt Black/Sand Beige
5 spd, 18" wheels
AH-64 Apache
RC-12 Guardrail
RC-7 Crazy Hawk
"If the wings are traveling faster than
the fuselage, it's probably a helicopter--
and therefore, unsafe" --Unknown
Rail26 is offline   Reply With Quote
Old 07-18-2005, 06:16 AM   #6
I had my 01 boxster its oil change 3,000 miles ago (during its 30,000 service) and I'm still waiting to add some 0W-40. Where is a good place to purchase Mobil1 0W-40? I tried PepBoys, Walmart and Target and though I haven't had to be too serious since the level is good I am thinking of being ready for when I have to add.
spgribben007 is offline   Reply With Quote
Old 07-18-2005, 08:12 AM   #7
deliriousga's Avatar
We run 15W50 with no oil consumption in 5K miles in the Boxster. I haven't tried the 0W40, but like spgribben007 said, I have not seen it anwhere around here either.
Maybe a special weight you can only get at the dealer? Like the $50/gallon coolant you can't find at an auto shop either?
1966 Wife White/Brown Top
