-   -   Dash Cluster Display Not Working (http://986forum.com/forums/performance-technical-chat/31310-dash-cluster-display-not-working.html)
stcroixdrew 08-09-2012 01:20 PM
The outer cover pulls off......the button under....has two tabs on side that are pushed in and then it slides out. Set screw is behind...
Jeffreybrucker 07-29-2018 06:28 PM
Hello...I am a new member...I just changed all of the instrument bulbs in my 97 Boxster to green LED's, looks amazing. However, in the process I must have done something wrong. The temp gauge, gas gauge, and clock are not working now. I didn't disconect the battery when I removed the cluster. I did try to reset the computer after by disconecting the battery for 30 min then turned the key to the on position for 60 seconds. Does anyone have any idea whet I could have done and how to fix it? Thanks!
particlewave 07-29-2018 08:01 PM
You didn't get the connectors seated properly. Pull them completely out, then try connecting them again. That will fix it. ;)
Geof3 07-29-2018 09:11 PM
As a note, it’s now sportscarleds.com. The super white looks really cool...
