-   -   P1119 (http://986forum.com/forums/performance-technical-chat/30948-p1119.html)
smshirk 11-05-2011 07:26 AM
P1119
I have a check engine light coming and going with code 1119. (P1119 Oxygen Sensor Heating 2 Ahead of Catalytic Converter - Below Lower Limit) Not sure if this means the O2 sensor is bad or not. Great if it is. It has come and gone off 3 different times in the last 1000 miles. I am just a month away from having to get my emissions check. I have a service visit scheduled but my luck the code won't be in at the time. Does anyone know if the inspection will show the code if it has cleared itself recently? I did clear it myself once, but that was over 1000 miles back. it stayed cleared for a few hundred miles. Since then it comes on and generally clears after the car sits overnight, staying off for at least one tank of gas.
Mrmaddbrad 11-05-2011 08:22 AM
You're OBC will store all CEL codes in it's memory unless cleared. So just be sure to make a note when you drop your car off.
