Old 10-18-2011, 01:56 AM   #1
Poor Performance after storage
Hi all,
I had my 2.7 in storage for about 18 months & the battery went flat. So I figured the ECU would need to to learn again but it has been a few weeks of constant driving, some highway & some around town.
I have been giving it a bit of stick as you should, & it still seems to be under-performing, & has a flat spot at around 4K rpm.
I have changed the oil & air filters, ran some injector cleaner through it & cleaned the MAF but still the same.
Coughed & spluttered a lot when 1st started up but no issues now.
Any idea's what else I can check.
http://i13.tinypic.com/49ied5h.jpg
2000 2.7 Boxster
aussieboxy is offline   Reply With Quote
Old 10-18-2011, 05:57 AM   #2
You could disconnect the MAF sensor wiring and see if the car runs better without it. My understanding is the car reverts to a set of stored lookup tables when it looses communication with the MAF. If it made a difference you could focus on the MAF. My local Porsche mechanic says he's never seen a MAF sensor successfully repaired by attempting to clean it. I bought some genuine MAF cleaner for my car but it didn't do anything. A new MAF solved my problems but I'm not trying to say your car has the same issues.
Dale_K is offline   Reply With Quote
Old 10-18-2011, 01:43 PM   #3
More info
I forgot to mention that the revs stay high between changes, ie it takes a second to drop the revs.
I will try disconnecting the MAF & see if it makes any difference.
2000 2.7 Boxster
