Old 10-03-2011, 08:10 PM   #1
Remove/deactivate cruise control
Does anyone know if you can deactivate or remove the cruise control safely from the 1999 Boxster? I find that I do not use it at all in my driving or track days, and occasionally find that the stalk is bumped and turned on by the dash icon. I worry about accidental activation.
Does anyone have experience doing this? Should I just pull the fuse?
It would be nice to get rid of since I never use it nor do I plan to.
Bryce is offline   Reply With Quote
Old 10-03-2011, 08:34 PM   #2
DenverSteve's Avatar
If you can pull a fuse that may be a way to go however I would never remove any wiring or render it (or anything else) inactive for future resale. I would never buy a vehicle that wasn't fully functional.
Denver Steve
DenverSteve is offline   Reply With Quote
Old 10-04-2011, 09:21 AM   #3
But if you do remove the complete system (modules, switches, relays, stalk, etc.) then I would be interested in buying it from you. I'd like to retrofit factory cruise to my '99. Be nice to have for the really long road trips.
'99 black 986
Old 10-04-2011, 09:47 AM   #4
To permanently deactivate it, you need access to a PST II or PIWIS unit; it is a setting in the DME.
Old 10-04-2011, 11:00 AM   #5
Even in the non-egas models?
'99 black 986
Old 10-04-2011, 11:34 AM   #6
Is it worth the effort? The throttle will over-ride the cruise control, and when you hit the brakes it will turn off.
Old 10-07-2011, 01:53 PM   #7
Opposed to Subie Burble
Overdrive's Avatar
Agreed. Even if it's activated by accident, a touch of the brake pedal turns it off imemdiately. I understand the concern, as it could be a problem on some cars, but I don't think you should be worried about it, and if you notice the light has turned on by you brushing against the switch or something, then you can just shut it off. Seeing as you have to press the switch forward (toward the front of the vehicle) in a very deliberate motion in order to set the cruise speed, it's not likely you'll activate it accidentally.
-O/D
IMSR + RMS
Robbins glass window top
Old 10-04-2011, 12:23 PM   #8
ppbon's Avatar
Yes...
... the Cruise function is in the ECU and turned on/off via a PSTII or PIWIS in all the models e-gas or not.
Happy Boxstering,
Pedro
ppbon is offline   Reply With Quote
Old 10-19-2011, 06:13 AM   #9
bar10dah's Avatar
I believe Durametric can also turn it on/off.
bar10dah is offline   Reply With Quote
Old 01-26-2015, 08:55 PM   #10
tutorial
see the post here
How to - 986 Cruise Control Retrofit - How To - www.BoXa.net
Dave1987 is offline   Reply With Quote
Old 01-27-2015, 01:25 AM   #11
Rennzenn
j.fro's Avatar
When the bulb went out in mine, the cruise control did not work. I believe if you pull the bulb you'll get what you want.
Rennzenn
Jfro@rennzenn.com
Old 01-27-2015, 02:51 PM   #12
Pedro,
Thanks for the helpful post. Always to the point.Unlike what follows.
Perhaps there would be merit to totally removing Cruise Control if:
1. it removed a troublesome accessory -is c/c unreliable -like SAI/AOS?
2. it made useful space to access troublesome components -see 1. above.
3. it reduced weight significantly(no)
4.It could be sold to buy the RMS/IMS/AOS you will need :-).
So which is it?
